Google Phone Dialer on Oneplus Phones
  1. lucah
    Froyo Feb 14, 2017
    Nimrodiny likes this.
  2. Bartnl
    Lollipop Feb 14, 2017
    Bartnl , Feb 14, 2017 :
    Why shouldn't it be compatible. You only need to disable the stock dialer.
    Magisk has a module for it to flash, so it does work.
    https://forum.xda-developers.com/oneplus-3t/themes/magisk-magisk-modules-oneplus-3t-t3548446
    Sun90 likes this.
  3. lucah
    Froyo Feb 15, 2017
    lucah , Feb 15, 2017 :
    So if I deactivate it threw the settings, the apk should install? I am going to try this.
    And yeah but you need Magisk (or how ever it is called) for this, abd I normally don't install other Recovery's, root, unlock bootloader when my device runs fine/get updates.
    Its like root is the answer for any question that you have on android, but not the best for everyone...
  4. lucah
    Froyo Feb 15, 2017
    nope1nope likes this.
  5. G_faizreylord_P_A_E_H_FI
    Donut Feb 15, 2017
  6. gauthambr
    Froyo Feb 20, 2017
  7. Centaurus
    Froyo Aug 29, 2018
    Centaurus , Aug 29, 2018 :
    I already use contacts and messages app from Google. I'd really like to also use Google Dialer app - OnePlus should integrate it in. Last time I used it was on a Nexus 5 and It's way better - I still miss the automatic identification number (web based feature).
  8. ghostofcain
    Marshmallow Aug 29, 2018
    ghostofcain , Aug 29, 2018 :
    Thankfully some kind user has already posted a link so you can use it.
  9. Centaurus
    Froyo Aug 29, 2018
  10. haseoxth
    Ice Cream Sandwich Aug 29, 2018
    haseoxth , Aug 29, 2018 :
    then you keep waiting for oneplus or google to do the job...
  11. ghostofcain
    And that my friend is why you get nowhere, the OP3(T) is EOL, don't expect massive improvements to the software now, so help yourself.
