3
Google Play Services 11.9.51 Introduces Battery Drain
Thread Status:
Not open for further replies.
  1. Deactivated User
    Dec 11, 2017
  2. runboy93
    Jelly Bean Dec 11, 2017
  3. VaibhavBhargava
    Lollipop Dec 11, 2017
  4. Deactivated User
    Dec 11, 2017
  5. Mr. BG
    Welcoming Expert, Community Hero 2020 Community Expert Dec 11, 2017
  6. Deactivated User
    Dec 11, 2017
  7. VaibhavBhargava
    VaibhavBhargava , Dec 11, 2017 :
    Yeah I checked on apkmirror but according to play store I can sign up for the 'beta' again. Lol
  8. Deactivated User
    Dec 11, 2017
  9. bulletant
    Froyo Dec 11, 2017
    bulletant , Dec 11, 2017 :
    I'm also on 11.9.51 but I didn't join the beta program. What's the versions you guys have?
  10. runboy93
    Jelly Bean Dec 12, 2017
  11. F_Andrea_Ippolito_ZsRS
    Ice Cream Sandwich Dec 18, 2017
    F_Andrea_Ippolito_ZsRS , Dec 18, 2017 :
    Following.
    Seems to be using a lot of WiFi
    I keep WiFi always OFF all the time, so having 3.5 hrs of WiFi used by Play Services over a 20 hour period is a bit too much to my taste...
  12. Vauhtiperttula
    Cupcake Dec 22, 2017
    Vauhtiperttula , Dec 22, 2017 :
    I have the same version too. Not beta tester. Here is a screenshot from my battery usage. 41% is crazy high in my opinion. I didn't have the same problems while using older version with my 5. Just moved to 5t and the problems surfaced whit the newest google play services update. Any solutions?
  13. damiroz
    Donut Dec 27, 2017
  14. Topper_Gas
    KitKat Dec 27, 2017
    Topper_Gas , Dec 27, 2017 :
    Clearing the Google Play Services cache and uninstalling then reinstalling the app updates usually works, although you then have to re-input any credit cards you have saved in Android Pay.
  15. damiroz
    Donut Dec 28, 2017
