google play services battery drain
  1. Richard_joel Cupcake Jul 22, 2019
    Richard_joel, Jul 22, 2019 :
    serious battery drainage in one plus 7 pro due to google play services..consumes almost 45% of my charge...i tried everything possible...turned off atusyc..restricted many apps...turned off many google activities...yet the problem persists...plzz give me suggestions to solve this problem.. unfortunately i cannot do hard reset
  2. Dresa91 Android Q Jul 22, 2019
    Dresa91, Jul 22, 2019 :
    use search function in this forum. there are several threads regarding Google Play Services and battery drain.
    no need for creating redundant threads!
  3. Richard_joel Cupcake Jul 22, 2019
  4. Richard_joel Cupcake Jul 22, 2019
    iam aware of that for ur kind information...and none of those threads has any useful information...soo there's no harm in starting a new one i suppose...soo if u have no suggestions regarding my issue then u may as well mind ur own business
  5. Dresa91 Android Q Jul 22, 2019
    did you really?
    two examples with more than useful information:
    1.
    https://forums.oneplus.com/threads/op3-3t-battery-and-heating-tips-nougat-oreo-pie.542075/
    2.
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    B_Wrath likes this.
  6. B_Wrath Marshmallow Jul 22, 2019
    B_Wrath, Jul 22, 2019 :
    Most of those threads have the answer, quite a few have the answers by @Dresa91 himself.
    Either you lie that you did a thorough search or you didn't try out anything suggested on those threads.
    Dresa91 likes this.
  7. Richard_joel Cupcake Jul 22, 2019
    B_Wrath
    Either you lie that you did a thorough search or you didn't try out anything suggested on those threads.​
    i did my through search and i did whatever i could as i have mentioned above guys..come on..why should i have to bluff regarding this
  8. Dresa91 Android Q Jul 22, 2019
    WHAT exactly did you try?
  9. B_Wrath Marshmallow Jul 22, 2019
    If you have tried everything, you are supposed to mention what you have tried. This reduces redundancy.
  10. Richard_joel Cupcake Jul 22, 2019
  11. B_Wrath Marshmallow Jul 22, 2019
    You didn't do the one thing mentioned on most of the threads. That's the first thing you should do.
    But hey, if you had done a thorough search, you should have known it by now.
    Dresa91 likes this.
  12. Dresa91 Android Q Jul 22, 2019
    again:
    WHAT did you exactly do?
  13. Richard_joel Cupcake Jul 22, 2019
    most of the threads have asked to do a factory reset or to clear cache... which is clearly of no use
  14. B_Wrath Marshmallow Jul 22, 2019
    And why did you come to that conclusion? And factory reset isn't the prime solution.
  15. Richard_joel Cupcake Jul 22, 2019
    god what Happened to u all....i have written it above..just have a look..i tried few things..but it didnt work out..i have mentioned it below the title
  16. Richard_joel Cupcake Jul 22, 2019
    i want a solution without the reset..thats the point...i have clearly mentioned it above
  17. B_Wrath Marshmallow Jul 22, 2019
    You mentioned two things. One is to clear the cache. Any do you think it is of no use? And what cache are you talking about?
  18. Dresa91 Android Q Jul 22, 2019
    so, without detailed information, WE USERS can't help you. WHY don't you understand?
  19. Richard_joel Cupcake Jul 22, 2019
    cache of the google play services obviously
  20. Dresa91 Android Q Jul 22, 2019
    one solution, which is mentioned in the links I shared and you obviously already did:
    did you install latest version of gps?
