Google play services draining battery
  1. Crysiszocker1
    Gingerbread Apr 8, 2015
  2. wilsmits
    Jelly Bean Apr 8, 2015
    wilsmits , Apr 8, 2015 :
    I have CM11s and no Oxygen! Does that matters???
  3. Android the Greek
  4. itfsos
    Eclair Apr 8, 2015
    itfsos , Apr 8, 2015 :
    This is old in fact but, as i said in my post, I think it was my wakelock problem. now my phone goes in deep sleep flawlessly and I don't have google play services in the battery stats.
  5. inFamous2
    Cupcake Apr 10, 2015
  6. azp3
    Jelly Bean Apr 10, 2015
    azp3 , Apr 10, 2015 :
    You can also use smanager and it's free. There is a learning curve.
    msugar7275 likes this.
  7. jdtimothy
    Eclair Apr 11, 2015
  8. msreekanth
    Cupcake Apr 13, 2015
    msreekanth , Apr 13, 2015 :
    I will check and let you know if it works.
    Thanks,
    Sreekant
  9. vysakh
    Honeycomb Apr 14, 2015
  10. reddybandi
    Eclair Apr 14, 2015
    reddybandi , Apr 14, 2015 :
    cleared the data of google play services solved the battery draining problem for me.
  11. dixie04
    Donut Apr 17, 2015
    dixie04 , Apr 17, 2015 :
    I did the deny bit, nothing changed. Saw your post. Key point was to reboot. Now sorted. Cheers.
    jainpraveen0407 likes this.
  12. Niels_Andersen
    KitKat Apr 17, 2015
  13. lila_gula
    Cupcake Apr 17, 2015
  14. keithnyc
    Marshmallow Moderator May 4, 2015
    keithnyc , May 4, 2015 :
    thanks....clear and easy
