187
Got a OnePlus problem? All you need to fix it yourself
  1. Marian1399 Cupcake May 6, 2017
  2. semicircle Cupcake May 7, 2017
  3. Peterrrrr Gingerbread May 10, 2017
    Peterrrrr, May 10, 2017 :
    I have problem with my 3G and 3g+ and data signal. Sometimes even if phone shows that I got signal I cant use internet, call and recieve call.
    I get an sms that people have tried to call me.
    I have tried alot of different modems but get the same result on all of them.
    I have tried alot of different 7.1 roms but get the same error on all roms.
    Anyone know any modem that really works with 7.1 roms? Right now I have install the Tugapower rom which is based on Lineage OS.
  4. F_Chandra_Mohan_sTwF Cupcake May 11, 2017
  5. mani jang shar Cupcake May 12, 2017
  6. nomad5810 Cupcake May 29, 2017
  7. jwdaryl Cupcake May 31, 2017
  8. TShark Donut Jun 2, 2017
  9. Vladm0 Cupcake Jun 5, 2017
  10. keith-davies Cupcake Jun 7, 2017
    keith-davies, Jun 7, 2017 :
    Can't find the answer to my problem and cannot request assistance until I've 5 replies apparently.
    Thanks anyway
  11. Jose7909 Cupcake Jun 18, 2017
    Jose7909, Jun 18, 2017 :
    Buenas actualice el recovery de mi Oneplus One y no puedo entrar en modo recovery q ahí ayuda
  12. pikota Marshmallow Moderator Jun 18, 2017
    pikota, Jun 18, 2017 :
    Stock recovery or twrp?
  13. kosmickeymouse Cupcake Jun 22, 2017
  14. Ahamid512 Cupcake Jun 22, 2017
  15. deividsz Cupcake Jun 22, 2017
    deividsz, Jun 22, 2017 :
    Hi, i got some issues with the network, at first looks like everything is normal, but when i make a call, the bars desapear, and most of the calls are Unsuccessfully, unly 1 of a 10 calls is success, and then the bars appear again, i really don't know if this problem begin when i repair the lcd touchscreen or on a upgrade system, i personally open the phone and check the antenna, is connected ok, can someone help me !?
    Hola, tengo algunos problemas con la red, al principio parece que todo es normal, pero cuando hago una llamada, las barras desaparecen, y la mayoría de las llamadas son Sin éxito, sólo 1 de las 10 llamadas es con éxito, despues de que la llamada falla regresan todas las barras, no se si este problema comienza despues de ser reparada la pantalla táctil de lcd o en una actualización, yo personalmente abri el teléfono y comprobe la antena si esta bien conectada , ¿alguien puede ayudarme?
  16. jeldertq Froyo Jun 23, 2017
    jeldertq, Jun 23, 2017 :
    Does anybody know where I can get a genuine replacement battery for my oneplus one. on ebay there are only fake ones
  17. khwangson Cupcake Jun 24, 2017
  18. tsukasa90 Cupcake Jun 30, 2017
    tsukasa90, Jun 30, 2017 :
    help please, i have full brick oneplus one i have use colorOS but not start after the boot phone go to power off.... help need very help
  19. sojibsays Cupcake Jun 30, 2017
    sojibsays, Jun 30, 2017 :
    My Oneplus one doing problem. its a just power on/off continuously. i try to hard reset but its fastboot moode not work.
    i dont know what should i do? please help me
  20. Suresh swis Cupcake Jul 2, 2017
