29
Got my oneplus 5, any questions?
  1. elanglois
    Lollipop Jun 23, 2017
    elanglois , Jun 23, 2017 :
    The Oneplus X was not an incremental upgrade to the OP2. That's my point. The half-year releases are not new flagship phones. The flagship phones are OP1, 2, 3, and 5.
    The OPX was an experiment, the 3T was a minor upgrade. I expect the 5 to be a major player like the 1 —> 2, or the 2—> 3, not a minor incremental update like the 3 —> 3T. Why isn't that making sense?
  2. cmcginty
    Cupcake Jun 23, 2017
    cmcginty , Jun 23, 2017 :
    Is there a notch at the top of the rear camera glass? I can't tell if that is damaged on my phone, or intentional. If it's on every phone, why?
    Matoja likes this.
  3. cmcginty
    Yes, I have the same as you. I don't know why it's like that, strange. They should've put the notch on the bottom if it's needed.
  4. G_Robert_R_QkZa
    Froyo Jun 23, 2017
  5. hot_as_fire
    Jelly Bean Jun 23, 2017
    hot_as_fire , Jun 23, 2017 :
    So it doesn't look like that?
  6. Minksgarg
  7. Voxprivat
    Eclair Jun 23, 2017
    Voxprivat , Jun 23, 2017 :
    Are you with TMobile? Have you tried TMo WIFI Calling, with the phone on Airplane Mode, so as to insure that the call can only be made via WIFI?
  8. iNtEnSePL
    KitKat Jun 23, 2017
    iNtEnSePL , Jun 23, 2017 :
    This is a place where NFC antenna resides, and they had tu cut the metal "ring" around the camera glass so it doesn't interfere with NFC. Just like whole body of OP5 and OP3 is cut with lines to make GSM/LTE/WiFi antennas work at all...
    Cons of a full metal body phone.
    cmcginty likes this.
  9. alvarezskinner
    Eclair Jun 23, 2017
    alvarezskinner , Jun 23, 2017 :
    anyway to edit in slow motion which part of the video is slow and which one is not as it's done in the iPhone?
  10. kevin_dedaniya21
  11. rahulhtd
    Gingerbread Jun 23, 2017
  12. Moin2200
    KitKat Jun 23, 2017
    hot_as_fire likes this.
  13. Moin2200
    KitKat Jun 23, 2017
    Moin2200 , Jun 23, 2017 :
    No worries that's just the antenna line.
  14. Moin2200
    KitKat Jun 23, 2017
    Not really sure, but yesterday it was raining like crazy and my 5 got really wet, I got still use it with no issues and when I came home a quick paper towel cleaned it nice and easy.
  15. Moin2200
    KitKat Jun 23, 2017
    Just an antenna line.
    As mentioned it's just the antenna for NFC.
    Well basically they reused the design from oppo r11
    No music app was pre installed when I received mine, only google play music.
  16. bombalicious
    Froyo Jun 23, 2017
    bombalicious , Jun 23, 2017 :
    Can you change gridsize?
    Can you set up custom values for notification lights (very short, slow/long)
    Gr
    Bombalicous
  17. harind3r
  18. Moin2200
    KitKat Jun 23, 2017
    Only when you change dpi scale not in launcher settings.
    No
  19. Moin2200
    KitKat Jun 23, 2017
    It's already in use when you fire up the camera, it helps with low light and zoom shots.
  20. bombalicious
    Froyo Jun 23, 2017
