29
Got my oneplus 5, any questions?
  1. PetroH
    Cupcake Jun 22, 2017
  2. Mohit_47
    Jelly Bean Jun 22, 2017
  3. elanglois
    Lollipop Jun 22, 2017
    elanglois , Jun 22, 2017 :
    It's never been a two step process. Stop fighting your phone. Why are you turning it off manually?
  4. DrAsghar
    DrAsghar , Jun 22, 2017 :
    I am getting the following issues after updating to Nougat
    1) Battery is draining too fast.It was very good in MM
    2)Camera focussing is very bad after MM
  5. Android450
    Marshmallow Jun 22, 2017
    Android450 , Jun 22, 2017 :
    1. Battery has to do with the apps you have installed you can follow this https://forums.oneplus.net/threads/op3-3t-battery-and-heating-tips-nougat.542075/
    To preform a clean flash download the 4.1.6 file from the OnePlus website directly from your phone browser.
    boot into recovery (turn off phone, hold volume down + power)
    click install from internal storage and click the 4.1.6 file.
    After it's done, boot into recovery again and wipe data and cache
  6. saikiran4ever
    saikiran4ever , Jun 22, 2017 :
    Does it have all the beta features like network speed in status bar, fonts, gaming mode etc. ?
  7. DrAsghar
    Thanks.
    Android450 likes this.
  8. B.yashaswi
    Ice Cream Sandwich Jun 22, 2017
  9. Android450
  10. Nithin_Joseph
    Nithin_Joseph , Jun 22, 2017 :
    Turning on data connection has been a two step process since Nougat. He's right.
    They made it two step to include the added feature of switching the data Sim.
  11. elanglois
    You missed the question. Why are you turning it off? Second, what are the two steps? Inrun Nougat, and don't have such issues.
  12. Android450
    Clicking two buttons is apparently too many steps lol
  13. elanglois
    I'm still lost. Which two?
  14. Nithin_Joseph
    Okay.
    1) Dash charging led notification : Many people want the option to customize the dash charging notification color from blue to something else.
    2) Data connection : It's been a two step process to turn on data since Nougat. The two "steps" being, clicking on the data/network icon from the notification panel, and then choosing it to be "on".
    There's also the added feature to switch data Sim.
    Dunno why you don't have that.
    And 'if' you're asking why he's turning the 'data' off, may be he's on an internet plan which has restrictions to how much data he can use.
    elanglois likes this.
  15. Android450
  16. elanglois
    1 .. how is this part of the discussion
    2 .. I normally have WiFi on, if I turn WiFi off, LTE comes on. I turn WiFi on, LTE goes off. I don't worry too much about data usage on LTE since I tend to not allow background data and keep data saver on pretty often rather than turning LTE off. Any app that rapes my data without my permission gets uninstalled. ES File Manager was replaced for that, Quickpic, and many others.
    Custom ROMs will let you toggle LTE in a single click should you still decide to manually it off (which doesn't help you when you do turn it on, so I would tame your apps). You can also have LTE off any time the screen is off.
    And yes, the question was why manually turn it off since Android wants to be connected all the time.
  17. elanglois
    I seem to remember that, but I never turn it off, I just turn WiFI ON. It's easier ... and I have single click toggles turned on (a feature OOS lacks)
  18. Nithin_Joseph
    Cool. I was just trying to answer your question like @Android450
    Apparently whatever you do, that particular user (including myself) doesn't lol
    Android450 and elanglois like this.
  19. Pd198554
    Donut Jun 22, 2017
    Pd198554 , Jun 22, 2017 :
    Does it have inbuilt call recording , if not can you check if any call recording apps work with the phone?
  20. immadeofpixels
    Eclair Jun 22, 2017
