24
Got my oneplus 7 pro, any questions?
  1. dermot33
    Ice Cream Sandwich May 21, 2019
    dermot33 , May 21, 2019 :
    Was same as you,hyped up to buy until I realized that the pro has some issues,the curved display has glare and gorilla glass 5 making the phone more fragile,for me anyway the phone is now too expensive and I don't want to end up with a situation where the phone drops and cracks just like all those cracked Samsung phones in recent years with curved edges,
    Your op6 is still good for another year at least and you will have the same software experience as the pro, more or less. Is it really going to be worth all that money.There are other reasons too,the cameras on the pro aren't meant to be great and you would struggle to see much difference between. shots taken on the 6,
    Perhaps there will be a 7T pro with flat display and other improvements. I will be holding on to my money form the time being anyway
  2. ceejaycee
    Gingerbread May 21, 2019
    ceejaycee , May 21, 2019 :
    Thanks for your opinion. I am a bit concerned about the curved screen as well. I'm going to go to a T-Mo store and actually hold one and see how much I dislike the curves before I commit. Thanks again!
    dermot33 likes this.
  3. Versed
    Honeycomb May 21, 2019
    Versed , May 21, 2019 :
    I have the older warp charger for my car, from what I've been reading it as well as the older chargers work, of course not at the same speed but still fast. It's just one or two things I don't have to order.
  4. Versed
    Something I should have done before I ordered from OP. Still used curved displays in the past and still would have ordered it. Shame they didn't offer the OP7 in the US.
  5. predator22
    Cupcake May 21, 2019
    predator22 , May 21, 2019 :
    I just moved from 8 years of using Galaxy.
    this kills me and I'm very close to return this otherwise a great phone. hope someone can help me
    I have over 150 apps and I always organize them in folders..in home screens and not app drawer.
    one plus ui seem to have HARDEST way to create a folder.
    you have to hold each app and copy to home screen first
    then drag them each one of icons to create/ put in a folder.
    no way I'm doing this for 150 apps.
    any ideas?
  6. neroleptic
    neroleptic , May 21, 2019 :
    you can add straight from the app drawer to the folder.
  7. predator22
    ahh. that works.
    I wish you can click + inside a folder and choose app from a list. like LG does.
    thanks
  8. z_c00l
    z_c00l , May 21, 2019 :
    Hi...any new on this? Thank you.
  9. gunturusrikanth
  10. Solution
    Froyo May 21, 2019
  11. A1558430763774
    A1558430763774 , May 21, 2019 :
    When I try to buy the 7PRO it take me to the accessories page, showing iteams like type-c cable, charger and earphone. I want to know that means the £799.00 phone do not include iteams like cable and charger? and btw if it can use O2 sim car thanks
  12. Moin2200
    KitKat May 21, 2019
    Moin2200 , May 21, 2019 :
    Charger, cable, screen protector and silicon case are all included in the box. It only takes you there in case you wanted somthing else. You can just skip it on the button of the page.
  13. Moin2200
    KitKat May 21, 2019
    Yes, there is also a case in the box.
  14. cosminsalasan
    Eclair May 21, 2019
    cosminsalasan , May 21, 2019 :
    the entire upper and lower frame of the clear case are higher. the corners are just at the same level as the entire upper/lower part. too lazy for pic but if you insist I can make one :)
    Tiger53 likes this.
  15. cosminsalasan
    Eclair May 21, 2019
    I have an issue with the "up" gesture. I belie it is partially due to the case or at least it contributed to it. whenever I push up from the home screen the drawer goes up so I have to make sure that I reach the very end of the screen to see the open apps. the big screen, as big as possible comes sometimes with shortcomings :)
    hopefully this can be fixed somehow with the future updates, assuming other users have the same issue
  16. Tiger53
    Froyo May 21, 2019
    Tiger53 , May 21, 2019 :
    Thanks a lot!
  17. cosminsalasan
    Eclair May 21, 2019
    Tiger53 and Sunil_31m like this.
  18. tobias14
    tobias14 , May 21, 2019 :
    use some other launcher like Nova Prime
  19. Ronin_2219
  20. Lachezar23
    Froyo May 21, 2019
    Lachezar23 , May 21, 2019 :
    I really would like to know how is the ultra wide angle camera. Is it as soft as the reviewers said or there is a difference. Also if possible try it in low light
