Got my phone today, best phone ever except one thing.
  1. chino1985
    Gingerbread Feb 15, 2015
    chino1985 , Feb 15, 2015 :
    So as it says above,got my OPO and been playing with it all day. Updated the phone as soon as I turned it on and no problems yet except for one thing. For some reason I can not seem to get my picture messaging working, I have tried about every post on here to try and get it to work. I called iWireless (T-Mobile affiliate) to see if they can figure out what's going on. Nothing, I can go without picture messaging if I must but really don't want to. I anyone can think of something to please help me out, I'm up for suggestions.
  2. C.Clowers
    C.Clowers , Feb 15, 2015 :
    Your APN settings must be exact....Google MMS setting for T-Mobile...there's one entry that's kinda tricky for all unlocked phones..my opo did that but I didn't have MMS correctly configured...
    chino1985 likes this.
  3. chino1985
    Its a T-Mobile affiliate but got it working after 3 hours of playing with the APN settings from of there old phones.
  4. ToddVolz
    Cupcake Feb 25, 2015
    ToddVolz , Feb 25, 2015 :
    I am in the same boat, what are your APN settings?
  5. chino1985
    Gingerbread Feb 25, 2015
    chino1985 , Feb 25, 2015 :
    Delete PIAPicture Messaging,
    Change iWireless to Web 2
    Change iWireless MMS to Picture Messaging
    Then go into Picture Messagin APN> under MMS proxy you will see 209.4.229.32, change it to 209.4.229.31
    Do not change anything else or your internet and picture messaging won't work!!!
    Picture messaging for me works most of the time but I'm in a small town, so hopefully in a bigger city it would work all the time.
    If that does not help then you will have to go into Web 2 and change APN type to default or internet (I usually get internet but no MMS with it just default or internet).
    richard.garsteck likes this.
  6. chino1985
    Also make sure you go into Network operators and register your phone with iWireless and not Iowa Wireless USA. That was a big mistake on my end when I first got my phone.
  7. ToddVolz
    Grr, still not working. Maybe it is because I'm in DSM and actually in a T-Mobile service area instead of being connected to iWireless towers...
    I can send the messages, but can't get the messages to download.
  8. chino1985
    iWirelss and T-Mobile use the same towers. If anything call iWireless and see if they can help or even better go to a iWireless store and have them help you.
  9. chino1985
    Did you wait for your service to be come active before you tried to send a picture? Sometimes is takes a minute or two. If it's orange instead of what that means its not totally connected to the network.
  10. richard.garsteck
    Gingerbread Aug 11, 2015
    richard.garsteck , Aug 11, 2015 :
    Good info Chino!
    I had to switch to iWireless and finally got around to looking for the "correct" APN's. Worked a charm!
    Sent from Hancock county
  11. chino1985
    chino1985 , Aug 11, 2015 :
    That's good it works. Hope your on 5.0.2. Since that update, I can send and receive MMS no problem. Its not spotty like it was.
  12. richard.garsteck
    Gingerbread Aug 14, 2015
