got oxygen 3.5.6 still volte is not supporting
  1. ketan.4
    Froyo Jan 4, 2017
    ketan.4 , Jan 4, 2017 :
    hey i just update my one plus 2 to os 3.5.6 which enable volte support but i am not able to make a call from jio as volte is not being displayed.please help me to solve this issue
    M.Tayyip likes this.
  2. Ambatti
    Eclair Jan 4, 2017
    Ambatti , Jan 4, 2017 :
    When did you get the update. Was it OTA and if so is your phone encrypted. Please let me know.
  3. dsmonteiro
    Infamous Mastermind Staff Member Jan 4, 2017
    dsmonteiro , Jan 4, 2017 :
    A few questions:
    • Are you using Dual SIM?
    • Is the Jio SIM card on Slot 1?
    • In which SIM card is data enabled?
  4. harshil.makwana
    Cupcake Jan 4, 2017
  5. SoniaB
    Community Hero 2020 Jan 4, 2017
    SoniaB , Jan 4, 2017 :
    Hey there
    Please see this thread now marked as Solved: https://forums.oneplus.net/threads/...ll-not-working-after-oos-3-5-6-update.482719/
    @ariblaze had the same issue as you have stated. He used Tony L's downgrade guide and then flashed the full 3.5.6 zip and the issue was fixed. See his post here:
    ketan.4, anuragnirmal and ariblaze like this.
  6. Sumukh.Violin
    Cupcake Jan 4, 2017
    Sumukh.Violin , Jan 4, 2017 :
    This issue is yet to be solved. Resetting the network settings will not help you. This is what I'm also facing right now. I have stopped using my jio sim
  7. ketan.4
    Froyo Jan 4, 2017
    yes it was ota but i downloaded it by using vpn
  8. ketan.4
    Froyo Jan 4, 2017
    G_Rajat_Lakkewar_YXNr likes this.
  9. ketan.4
    Froyo Jan 4, 2017
    i tried this also.did u get result by this process
  10. ariblaze
    Jelly Bean Jan 4, 2017
    ariblaze , Jan 4, 2017 :
    Try the method mentioned above. That worked for me. It will work for you as well. It is just that it is a bit time taking process but it works.
    SoniaB likes this.
  11. ariblaze
    If it is a VOLTE related issue where you are using a JIO sim and VOLTE is enabled in Sim settings and still you are not getting VOLTE icon on status bar and you are unable to make calls using JIO sim, then this will definitely work.
    ketan.4 likes this.
  12. user 7
    Ice Cream Sandwich Jan 4, 2017
    user 7 , Jan 4, 2017 :
    Reset network settings and reboot
  13. Narendran Reguraman
    Cupcake Jan 4, 2017
  14. shivagonal
    Cupcake Jan 4, 2017
    shivagonal , Jan 4, 2017 :
    I faced this problem too. Rebooting the phone solved I guess. I'm not sure fully
  15. ketan.4
    Froyo Jan 5, 2017
    ketan.4 , Jan 5, 2017 :
    dual sim.slot one.jio
  16. m1tch3m
    Ice Cream Sandwich Jan 5, 2017
    m1tch3m , Jan 5, 2017 :
    In the SIM & network option in settings should it show the option to use VoLTE (enhanced feature) option to enable or disable even if the network provider you're with doesn't support it? As I don't see the option at all :(
  17. ariblaze
    Jelly Bean Jan 5, 2017
    ariblaze , Jan 5, 2017 :
    It will only show if the carrier supports Volte (Ex - Jio in India, T-Mobile in US). Moreover Volte has been enabled for selected carriers as per the update log.
    m1tch3m likes this.
  18. Dinesh.D
    Cupcake Jan 5, 2017
    Dinesh.D , Jan 5, 2017 :
    Even I have no option for volte in v3.5.6.
    I updated it via a VPN.
    any suggestions , or OnePlus Team plz give a fix..
    ketan.4 likes this.
  19. ketan.4
    Froyo Jan 5, 2017
    help me too
  20. ketan.4
    Froyo Jan 5, 2017
