43
GPIO switch
  1. ruff1003
    Cupcake Aug 19, 2017
    ruff1003 , Aug 19, 2017 :
    Thanks for helping, found it but is not deactivated nor force closeable
  2. asasione
    Ice Cream Sandwich Aug 19, 2017
    asasione , Aug 19, 2017 :
    You can either go through Play Store > Play Protect
    Or
    Settings > Google > Security > Google Play Protect
    Scan again and disable when they prompt for action
  3. G_Chandra_sekhar_oRMM
    Gingerbread Aug 19, 2017
  4. ruff1003
    Seems it wasn't my day haven't found it so far, even Google it and everything but now with your help I was able to deinstall it.
    Really thanks for helping me.
  5. Burgess85
  6. Darekb81
    Honeycomb Aug 19, 2017
  7. David.l11
    Donut Aug 19, 2017
  8. G_Hanspeter_Holzer_iOUl
    Cupcake Aug 20, 2017
    G_Hanspeter_Holzer_iOUl , Aug 20, 2017 :
    Hello,
    this is happening right now on every OnePlus 3. Every OP3 owner I know has asked me about it (since I'm kinda the IT support guy in our surroundings).
    Personally, I've made a backup of this app with Titanium Backup and afterwards I've uninstalled it.
    Regards,
    HP
  9. pedro.taveira
    Donut Aug 20, 2017
    pedro.taveira , Aug 20, 2017 :
    Also appeared. Now it is disabled. Would be good to understand the reason behind this app and what (if any) is the risk... I believe it is only the phones with the latest beta (22/13), correct?
  10. G_Spaceallday_CqMw
    Eclair Aug 20, 2017
  11. fm.garcia
    fm.garcia , Aug 20, 2017 :
    I guess we need to buy an OP5 to get some attention... Love my OP3, But I think this is it for me
  12. KyaNani
    Honeycomb Aug 20, 2017
    KyaNani , Aug 20, 2017 :
    Its a spare input and output, if the OP phone has spare pins in their hardware, the access to the Kernel which is the GPIO switch can activate this spare hardware, this is potentially dangerous since it can be used for by bad elements. I think Oneplus must issue an explanation to clarify this. Good job Google in detecting this!
  13. a5pe4
    Gingerbread Aug 20, 2017
    a5pe4 , Aug 20, 2017 :
    Why wouldn't OnePlus clarify what that switch is needed for?? You can't just add something like that and expect everyone to trust you
  14. xankazo
    xankazo , Aug 20, 2017 :
    I also got this warning on my OP3 on the Open Beta 22. What the heck is this supposed to be?
  15. MedicBCAA
    MedicBCAA , Aug 20, 2017 :
    Same,.... I'm just going to ignore it personally.
    If they come out with something then so be it... otherwise I haven't had an issue yet, even though it is all the sudden "dangerous" for my OP3.
  16. SidMAX86
  17. derLenno
    The Lab - OnePlus 6 Reviewer Aug 20, 2017
    derLenno , Aug 20, 2017 :
    I think it's an interference between the real use of the app and a "rule" Google's safety check has. I've only had this message on my Samsung devices when I had SEPolicy switcher installed.
    My thoughts on this: It's a deep-level system app that should be whitelisted by Google but actually isn't and thereby it's treated like 3rd party apps such as SEPolicy Switcher and alike. But please don't nail me down on that
  18. nikoul
    nikoul , Aug 20, 2017 :
    I have the same problem here, with stable Android/OxygenOs builds. I hope someone from oneplus will tell us something soon.
    #38
  19. alexferdean
    Ice Cream Sandwich Aug 20, 2017
    alexferdean , Aug 20, 2017 :
    Don't panic! This app was always here, but Google recently launcher the Google Play Store Protect and only now it detected this app as harmful. Definitely OnePlus should issue a statement regarding this.
    #39
  20. F_Frédéric_Villanova_M
    #40
