43
GPIO switch
  1. accessive
    Cupcake Aug 20, 2017
    accessive , Aug 20, 2017 :
    I'm curious to know if anyone here that has this popup/issue is using stock Android kernel that came with the phone? Being a user of a custom kernel, that comes to mind. Perhaps this is related to a change of kernel? just thinking out loud so to speak.
    after i know that, i can at least determine the "risk factor" involved. at the moment I'm off the opinion this is just a false flag by new Google/Android security rules. but if it's custom kernel related, that could present a bigger risk. (doesn't mean it makes it harmful, just means the risk is there)
    #41
  2. ZoroKoBoro
    Honeycomb Aug 20, 2017
    ZoroKoBoro , Aug 20, 2017 :
    Hello everyone i got a notification from Google play Store that this app is harmful and suggested me to disable it. Any one has any idea what this app is? and is it a system app of OnePlus. Please help me on this.
    #42
  3. ZoroKoBoro
    #43
  4. RiDEN
    Froyo Aug 20, 2017
    RiDEN , Aug 20, 2017 :
    Stock kernel, also had this warning.
    #44
  5. AltLin16
    Ice Cream Sandwich Aug 20, 2017
    AltLin16 , Aug 20, 2017 :
    No warning here with 4.1.6 after rescan. As others observed a system app that quite likely should not be notified by a PlayStore or vice versa if there is a security problem maybe rather fixed than disabled. A calrifcation by OP would be appreciated. on the other hand there is an option in playprotect to notify also Google in such cases.
    #45
  6. Yash Bhardwaj
    Jelly Bean Aug 20, 2017
    #46
  7. AltLin16
  8. AltLin16
  9. Raincat
    Raincat , Aug 20, 2017 :
    Useful info, thanks everyone. But being completely non-teccy I don't understand most of what's written. Is the general consensus to just ignore the message, or should I click on uninstall harmful app? I haven't installed anything new recently, so don't know which app the message is referring to... Any advice grateful received please! Thanks again
    #49
  10. G_juan_antonio_rodrigo_L
    Eclair Aug 20, 2017
    G_juan_antonio_rodrigo_L , Aug 20, 2017 :
    [QUOTE = "pedro.taveira, post: 16672356, member: 745231"] También apareció. Ahora está deshabilitado. Sería bueno entender la razón detrás de esta aplicación y qué (si es que) es el riesgo ... Creo que sólo los teléfonos con la última versión beta (22/13), ¿correcto? [/ QUOTE]
    Yo con todo stock también he recibido el aviso.
    4.1.6
    #50
  11. Jhonnay
    Gingerbread Aug 20, 2017
    Jhonnay , Aug 20, 2017 :
    i can't find the option for Google play
    i can't even find Google play protect on the play store?!
    #51
  12. pedritopl
    pedritopl , Aug 20, 2017 :
    Settings -> Google -> security -> Google Play Protect
    I just checked mine. OP3T with latest Beta13, scanned 1h ago - no warning. I also made sure that the GPIO Switch app is on the list of system apps...
    Either Google learned that it was a false positive and stopped reporting it as a harmful app or so many people got infected with some malware. I guess the first option.
    #52
  13. Jhonnay
    no, you didn't understand what i meant
    i can't find the option for play proiect in the settings under Google.
    and i can't find Google protect on the app store
    #53
  14. pedritopl
    I also don't have it in the Play Store. Just in the Settings. If You can't find it there then maybe the option to show it was not activated yet by Google for your account. AFAIK they were rolling it out gradually. Anyway the protection should be there, it's just not shown in the menus.
    #54
  15. Jhonnay
    i going to research this
    but nevertheless than you for your help
    i appreciate it
    #55
  16. pedritopl
    #56
  17. Jhonnay
    #57
  18. SteveB`
    Froyo Aug 20, 2017
    SteveB` , Aug 20, 2017 :
    I didn't get that notification so I guess my phone is going to get really hot, the batteries are going to swell up and the phone is going to explode when I have it by my ear and take half of my head off.
    Can you spell melodramatic?
    #58
    Deactivated User likes this.
  19. xkiddoh
    xkiddoh , Aug 20, 2017 :
    I cant even disable it.. I didnt get the popup though.. Ive no idea what play protect is..if its an app..i dont have it.. Im on beta 13 right now.. Any ideas?
    #59
  20. Darekb81
    Darekb81 , Aug 20, 2017 :
    So if this was false positive and I have disabled GPIo switch by play protect, does anybody knows how to re-enable it?
    #60
    AGPlugged likes this.
