GPS is not working in OP3T
  1. laxy1203
    Cupcake Nov 5, 2018
    laxy1203 , Nov 5, 2018 :
    Hello,
    GPS is not working in OP3T, Please help.
    Android version: 8.0.0
    Oxygen : 5.0.6
    Thanks
  2. karthik oneplus
    Ice Cream Sandwich Nov 5, 2018
    karthik oneplus , Nov 5, 2018 :
    Please use search before creating new thread . This is an issue with 5.0.6.
    For temporary fix use this app I did it twice to make it work on my 3T.
  3. Romesh1964
    Eclair Nov 5, 2018
  4. karthik oneplus
    Ice Cream Sandwich Nov 6, 2018
    karthik oneplus , Nov 6, 2018 :
    I have an update that app didn't fix it. I tried safe mode and still there seems to be an issue.. Will call oneplus and report it probably you should also do that so they can push in next update.
  5. Narender
    Eclair Nov 6, 2018
    Narender , Nov 6, 2018 :
    I have the same problem but i found the cure
    The problem is that if u close the location after reboot and again on it.. It will not work.. U have to reboot it
    The only way is that never close location if u close the location u have to reboot with location on
    Hope this works it works for me
