GPS issue
  1. anbuitachi
    Eclair Oct 26, 2014
    anbuitachi , Oct 26, 2014 :
    I am unable to locate anything with GPS (tried google map, GPS test, couple others). For my google map, if i put it on Device only, it just shows "waiting for location". When I use GPS test, it shows "No Fix". I used GPS test in the same spot, with my tablet with GPS only, and I easily got a fix!.
    So what is up?? does my phone not have a gps or something (I need to know i'll be able to have gps if im stuck in the mountains w/ no wifi/service)
    aivir likes this.
  2. TeumessianFox
    Eclair Oct 26, 2014
    TeumessianFox , Oct 26, 2014 :
    You have GPS. I had trouble with it for a bit, then an update was pushed through. You also need to make sure that you allow google the ability to "track your info", or w/e it says. That will improve accuracy etc.
  3. anbuitachi
    Eclair Oct 26, 2014
    it shws No Fix when i use GPS test.. i gave google ability to track me. what do you mean an update? my phone is on latest
  4. Casper5555
    Gingerbread Oct 26, 2014
  5. anbuitachi
    Eclair Oct 26, 2014
    Casper5555 likes this.
  6. Iseek1
    KitKat Oct 26, 2014
    Iseek1 , Oct 26, 2014 :
    go to Settings > Personal > Location and switch to "ON"
  7. Iseek1
    KitKat Oct 26, 2014
    my OPO on 38R and GPS Test works perfectly, here is a screen shot;
  8. anbuitachi
    Eclair Oct 26, 2014
    location is On. i can't set it to device only w/o turning location on.
    is my phone defective????
  9. tanja3981
    Froyo Oct 26, 2014
    tanja3981 , Oct 26, 2014 :
    Hello
    I have the same problems here, no fix with GPS. The location can be detected only by googles wifi locations. AGPS is up to date, as well as any software.
    I reported an support request at OPO one week ago, but still no response.
    Tanja
    Ukali and anbuitachi like this.
  10. anbuitachi
    Eclair Oct 26, 2014
  11. Jugher
    Jugher , Oct 26, 2014 :
    It takes awhile... I also had the same happen to me... I turned it on and no lock in GpsTest, but after a day it started working... And when I launch GPS test now I get the lock immediately. But it is a little strange, yes.
  12. anbuitachi
    Eclair Oct 26, 2014
    it took a day?!
  13. anbuitachi
    Eclair Oct 26, 2014
  14. anbuitachi
    Eclair Oct 26, 2014
  15. Chevanlol360
    Honeycomb Oct 26, 2014
    Chevanlol360 , Oct 26, 2014 :
    ABOUT A WEEK AGO
  16. quintenquist
    Cupcake Oct 27, 2014
    quintenquist , Oct 27, 2014 :
    Yep, I have issues, too with GPS. The navigator starts real slow because even with precise location settings finding the current location takes up to 10 seconds.
  17. lokkust
    Donut Dec 7, 2014
    lokkust , Dec 7, 2014 :
    Having Issues with GPS it is very un reliable and is taking a long time to get a fix. while on my old iphone 4s it does it instantly.... is this a hardware issue or a software issue?
    Nangi likes this.
  18. ExpatZ
    Jelly Bean Dec 7, 2014
    ExpatZ , Dec 7, 2014 :
    10 seconds is not slow. You have no problems with GPS locking.
  19. lokkust
    Donut Dec 7, 2014
    Ok guys GPS fix for the One plus one found on reddit. thank you user: "nbuster"
    I did have issues. The GPS' compass could not lock onto my orientation.
    I downloaded GPS Status and ran it, let it do its thing. It calibrated everything perfectly.
    It is now by far the most accurate GPS I've had, and I don't say it lightly (previous owner of SGS3, LG G2)
    Hope it helps :)"
    Aaahh likes this.
  20. Aaahh
    Marshmallow Dec 7, 2014
    Aaahh , Dec 7, 2014 :
    Go to 44.
