Vandit_S.S , via OnePlus 5T , Mar 12, 2020 : Okay., but I'm not facing it. Express it more in detail.
MIHIRJOGANI , via OnePlus 5 , Apr 16, 2020 : Everytime I input a destination it's fine when I click on start navigate it doesn't follow up right away and it's annoying.
Aamir Aman , Apr 27, 2020 : it's the same with me. The gps just doesnt work. arrow head does not show in google maps. only a solid dot
pauliprokki , Apr 27, 2020 : GPS is always slow and doesn't follow you in right away. Alsom, if there is cloudy wather or lots off tall building around you, GPS search takes few seconds.
Aamir Aman , May 5, 2020 : I FINALLYYY got a solution!!! Upgrade your OP5 to Android 10 Open Beta 2. That should solve your problem too
MIHIRJOGANI , via OnePlus 5 , May 5, 2020 : I'll have to try it and see I do have the the updated version
Aamir Aman , May 5, 2020 : sounds good! I'm sure it will work for you as well. Let me know if it does. you can always check out this YouTube link to guide you better.
