gps/navigation bugs/issue
  1. Machete
    Cupcake Aug 8, 2017
    Machete , Aug 8, 2017 :
    hey guys, ive got the opo5 since release and im quite happy with it BUT and yes this BUT is huuuuge, i got a issue with the gps system:
    When i enable gps, my position is located (via mobile and wifi) this works good for gmaps and here. when im setting up the navigation i get the best routes and traffic situation displayed. everything good until here.
    when i choose "start navigation", gapps or even here are doing nothing, im standing on the same point all the time, no active movement.
    strange is: when i tab "back" and i get into the route options i see my position moving....
    please help!
    if this is the wrong category feel free to move it.
    best regards
    machete
  2. javaid ahmad
    Eclair Aug 8, 2017
  3. wileyc
    Jelly Bean Aug 8, 2017
    wileyc , Aug 8, 2017 :
    First check that GPS is working by using GPS Test app from Google play store. That will tell you if your phone is getting g a satellite fix. As far as I know there is no way to enable and disable GPS ...only location setting. Ensure that is on high accuracy.
    If all else fails clear the system cache via the recovery mode.
    remedy likes this.
  4. loojiay88
    Donut Sep 23, 2017
    loojiay88 , Sep 23, 2017 :
    Do you happen to have DJI app installed? Coz my GPS is working again after uninstalling it and clear cache
