GPS navigation issue on OP5
  1. deb1806
    Gingerbread Sep 6, 2017
    deb1806 , Sep 6, 2017 :
    my navigation is not working properly and instead of an arrow it shows a dot . Tried formatting also, same thing persists.
    If there is any fix for this bug pls comment below
    OOS 4.5.10
  2. loojiay88
    Donut Sep 23, 2017
    loojiay88 , Sep 23, 2017 :
    Do you happen to have DJI app installed? Coz my GPS is working again after uninstalling it and clear cache
  3. G_Wong_Soon_Kheng_(Kheng
    Donut Sep 25, 2017
    G_Wong_Soon_Kheng_(Kheng , Sep 25, 2017 :
    I have the DJI App installed. Maybe you're right. So ur GPS works perfectly fine after uninstalling the DJI App? Which version of Oxygen are you at now?
  4. G_Gur_Sharon_bevN
    Donut Sep 25, 2017
    G_Gur_Sharon_bevN , Sep 25, 2017 :
    I had the same problem, also posted a while back but got no response..
    My solution was to use "device only" as the location settings. Haven't got the DJI app, whatever that is
  5. loojiay88
    Donut Sep 25, 2017
    loojiay88 , Sep 25, 2017 :
    Yup. It'd working again and I can get 3D fix in GPS test app. Currently on 4,5,0
  6. F_Debjyoti_Mathuli_jSJx
    Donut Sep 25, 2017
  7. G_Wong_Soon_Kheng_(Kheng
    Donut Sep 25, 2017
  8. Geeky
    Froyo Sep 25, 2017
