GPS Problem!
  1. O1516348754735 Cupcake Feb 22, 2019
    O1516348754735, Feb 22, 2019 :
    Hi,
    Since latest updates from OnePlus, i am experiencing problem with GPS location.. both Waze and Google Maps cant connect to GPS although it showing the routes..
    please help
  2. GilBates Donut Mar 8, 2019
    GilBates, Mar 8, 2019 :
    Same problem with mine ... waiting for an update that will solve this troubleshooting.. Why updating and creating problems to devices that worked perfectly ???
    vinodshrmaa likes this.
  3. O1516348754735 Cupcake Mar 8, 2019
    O1516348754735, Mar 8, 2019 :
    hi my gps problem already solved.. have u try clearing cache ? My gps back to normal after I clear cache.
  4. T1558073726464 Cupcake May 17, 2019
    T1558073726464, May 17, 2019 :
    Same problem.. Not able to fix it..
    The location service/GPS is not working in my OnePlus 6T. The Phone keeps searching for location without any results.
    This has happened after the recent update.. None of the suggestions available online seems working as the settings interface is not user friendly at all.. Can't access the proper settings.
    Any help/suggestions...
  5. Wackencorpse KitKat May 17, 2019
    Wackencorpse, May 17, 2019 :
    This topic is about a GPS Problem with OnePlus 5/5T. You should open a thread in den OnePlus 6 subforum. No problem with GPS and OP5 so far.
  6. vinodshrmaa Cupcake Jul 18, 2019
    vinodshrmaa, Jul 18, 2019 :
    I also have the same issue with GPS. It keeps searching in oneplus 6T. It is really painful to see this issue in flagship device.
  7. Waveform Modifier Marshmallow Jul 18, 2019
    Waveform Modifier, Jul 18, 2019 :
    Wrong forum
