8
gps problem
  1. G_Miguel_Silva_qpRz Cupcake Sep 13, 2017
    G_Miguel_Silva_qpRz, Sep 13, 2017 :
    hi there !
    after the last update my GPS is not working properly which renders google maps useless since it does not update my location as I move.
    could you provide with a solution for this?
    thanks and best regards
  2. lmlyhm Cupcake Sep 13, 2017
  3. nobelium76 KitKat Sep 13, 2017
  4. Telegtron Cupcake Sep 14, 2017
  5. furro Cupcake Sep 14, 2017
    furro, Sep 14, 2017 :
    I had the same problem since last update.
    I resolved with downgrade to 4.1.6.
    Im not root and bootloader block.
    Download the rom and install from the recovery stock. Very easy.
    Sorry my English
  6. furro Cupcake Sep 14, 2017
    I try some things before. Restoredefault, erase AGPS, but nothing repaire.
    The solution is the downgrade to 4.1.6
  7. F_Aaron_Koh_PcGa Cupcake Sep 14, 2017
  8. Sinnaz0709 Honeycomb Sep 14, 2017
    Sinnaz0709, Sep 14, 2017 :
    guys I'll strongly recommend using the bug report ....I did they did some tests and gathered logs for review..may be if all that's affected do same they would actually see your complain and so the same as they did with myself and may be release a fix...
    complaining in general forums not going to do much... so make use of the bug reporting ....
    G_Mr_aNfL likes this.
  9. rarog Lollipop Senior Moderator Sep 14, 2017
  10. G_Nadim_M_NDwx Cupcake Sep 14, 2017
    G_Nadim_M_NDwx, Sep 14, 2017 :
    Also have the issue. Clearing agps or reboot. Clearing cache helped for a while. Will do a bug report
  11. G_Nadim_M_NDwx Cupcake Sep 14, 2017
  12. SilverGlove Ice Cream Sandwich Sep 14, 2017
    SilverGlove, Sep 14, 2017 :
    Go to Settings - Apps - Maps and uninstall Updates.It Should work
  13. digesh055 Cupcake Sep 14, 2017
  14. G_Cheah_Liat_Hui_PROV Cupcake Sep 14, 2017
    G_Cheah_Liat_Hui_PROV, Sep 14, 2017 :
    go to app store
    find maps app
    click uninstall
    it will ask whether you want to uninstall updates, click yes.
    restart you're phone.
    This steps should fix your problems for now.
  15. Harvie H. Bug Hunter Sep 15, 2017
    Harvie H., Sep 15, 2017 :
    Thanks Rarog:
    Guys:
    Firstly, please check the surrounding environment, if possible we want to know the performance of ref devices in same place.
    Secondly, Please capture the log for us:
    1. Input *#800# from dialing interface, enter "oneplus logkit", delete history log
    2. Enter “Wireless connection”, click “get gps log info”
    3. Go back to last stage, click "save log"
    5. Click "get QXDM Log", choose "GPS-related", roll down, click "open device log"
    6. Make the issue reproduce and take a screenshot to record the time, then stay for a few minutes (better above 10 minutes)
    7. Click “save log” again to stop it, enter QXDM Log and choose “close device log”.
    8. Finally, enter file manager>storage>oem_log, find the folder, zip it and send it to us along with the screenshot
    my email address is : harvie.he@oneplus.net
    Thanks a lot
    Looking forward for your supports.
    Harvie
    Sinnaz0709 likes this.
  16. G_Paulo_Robson_RTVe Cupcake Sep 21, 2017
