3
Grarak VS Seraph08 builds
  1. cnl
    Honeycomb Mar 24, 2016
    cnl , Mar 24, 2016 :
    I've clean installed Seraph08's Build on my OnePlus Two and I cant connect to my Wifi... Anyone's got a solution for this?
  2. Hellgamer
    Froyo Mar 25, 2016
    Hellgamer , Mar 25, 2016 :
    I've flashed his latest, but flashed benscholds kernel at the same time, which hasnt got graraks latest edits yet afaik. But i still have to say, the battery life is definitely increased! went from 4 to 5H SOT
  3. Hellgamer
    Froyo Mar 25, 2016
    try enabling the old 5.1.1 DHCP wifi client in developer options?
  4. venky1+1
    Honeycomb Mar 25, 2016
    Hellgamer likes this.
  5. TbagBaggins
    Apr 5, 2016
    TbagBaggins , Apr 5, 2016 :
    My highest score is 80k how is your phone performing with twice the power of mine
  6. Deactivated User
    Apr 5, 2016
  7. TSluggard69
    Gingerbread Apr 5, 2016
    TSluggard69 , Apr 5, 2016 :
    overclock
  8. Bidzas
    Froyo Apr 5, 2016
    Bidzas , Apr 5, 2016 :
    Dumb question. Why can I easily find the Grarak CM ROM here on the OP forums, but the Seraph08 one does not appear on the first page?
  9. cypher
    Honeycomb Apr 5, 2016
    cypher , Apr 5, 2016 :
    because ROM thread popped up on XDA, and there it remains.
  10. Bidzas
    Froyo Apr 6, 2016
    Bidzas , Apr 6, 2016 :
    Thanks! I'm not really familiar with XDA forum. I guess I have to spend more time over there ;)
  11. Seraph08
    Froyo Apr 23, 2016
    Seraph08 , Apr 23, 2016 :
    He has decided/allowed his ROMs to be posted here at the OP forums along with his twitter account. I can respect that and leave the situation as it is. There is no need for mine to also be here. It is easy enough to find me over at XDA.
  12. Seraph08
    Froyo Apr 23, 2016
    and yes of course some of my code is based on the work Grarak has done. Come on the freaking guy did the original device tree. But you are more then welcome to do a compare at github between his and mine. Don't for get my oppo device tree also.
    gopinathr likes this.
  13. gaster
    Moderator Moderator Apr 23, 2016
    gaster , Apr 23, 2016 :
    A poll would be cool here i think. Does FPS, LAF and AS working in the Seraph's builds?
  14. Seraph08
    Froyo Apr 23, 2016
  15. ratification
    Ice Cream Sandwich Apr 23, 2016
    ratification , Apr 23, 2016 :
    That totally happened to me
    I had it with cm13. On oos3.0, Wi-Fi doesn't auto disconnects, but slows down significantly.
  16. Seraph08
    Froyo Apr 23, 2016
    a lot of my users at XDA are reporting my builds are not having that issue. naturally some people still get it, but the majority of the users have said its fixed.
    Hellgamer, aneesimran and dinjesk like this.
  17. Seraph08
    Froyo Apr 23, 2016
    I've also got a few CyanogenMod 13.1 ROMs in my basketbuilds for testing. Myself not really recommending them as daily drivers but they are worth trying them out if you are that type of person.
  18. smrdelj
    Gingerbread Apr 24, 2016
    smrdelj , Apr 24, 2016 :
    hi! May i ask you two questions?
    1) what do you say about camera in your build?
    2) your rom is fully compatible with boefflas kernel, right?
    Thanks for your work man!
    #38
  19. Seraph08
    Froyo Apr 25, 2016
    Seraph08 , Apr 25, 2016 :
    the camera on the build im running right now is probably the best its been ever/long time.
    yes fully compatible i know many of my users use it.
    #39
    smrdelj likes this.
  20. smrdelj
    Gingerbread Apr 25, 2016
    smrdelj , Apr 25, 2016 :
    thanks for answering, I'll try your build!!
    #40
