20
Great to list problems here ONE PLUS 3T
  1. Evrim95
    Cupcake Dec 25, 2016
    #61
    Nalintha likes this.
  2. jerrymilton
    Jelly Bean Dec 25, 2016
    #62
  3. Sugu Mar
    Eclair Dec 26, 2016
    #63
    Fi3 and puneeth12 like this.
  4. Jianyu Zhu
    Cupcake Dec 26, 2016
    #64
  5. Dexxagon
    Honeycomb Dec 26, 2016
    Dexxagon , Dec 26, 2016 :
    still I'm not facing any issue..but it happens when 4G enabled..
    #65
  6. Dexxagon
    yes mate.. I'm feeling that too..
    #66
  7. Dexxagon
    Yes, that's why they created an revolution.Bringing high end specs to budget phone..that's the beginning of it's..evolution..!!!
    #67
  8. achievvicky
    achievvicky , Dec 26, 2016 :
    Along with the below listed issues, please check about the swipe for making the calls feature even through from msg platform because now a days all brands are providing that feature now even Truecaller is also providing.
    You should also look into this now.
    #68
  9. hi5arp
    Gingerbread Dec 26, 2016
    hi5arp , Dec 26, 2016 :
    Use battery monitor widget.
    They are displaying of Op3, i guess.. which shouldn't be like that.
    #69
  10. hi5arp
    too felt the same when k was charging it for the 1st time
    After that, I haven't felt that again.
    #70
  11. Karan_Sarraf
    Eclair Dec 26, 2016
    Karan_Sarraf , Dec 26, 2016 :
    Same here with oxygenOs 3.5.4
    #71
  12. sumit.anand
    Donut Dec 26, 2016
    sumit.anand , Dec 26, 2016 :
    If you have 3t 64 gb then check its battery rating... By downloading CPU Z app...
    #72
  13. F_Gopi_Barnala_VkSl
    Eclair Dec 26, 2016
    #73
  14. runboy93
    Jelly Bean Dec 26, 2016
    runboy93 , Dec 26, 2016 :
    Default video player D: who really uses it.
    #74
  15. UltrAs81
    Froyo Dec 26, 2016
    UltrAs81 , Dec 26, 2016 :
    Deactivate pocket mode, i've had the same problem and now the fingerprint sensor is working as intended.
    #75
  16. DushyantVaghela
    #76
  17. Karan_Sarraf
    Eclair Dec 28, 2016
    Karan_Sarraf , Dec 28, 2016 :
    I check it but it dosen't shows correct for me because when my battery is full charged then it shows 20 hours then when it drops to 83% then it shows 6 hours? I'm not really not liking my battery draining issue with wity oxygenOs 3.5.4.
    #77
  18. prashantrana
    Eclair Dec 30, 2016
    prashantrana , Dec 30, 2016 :
    Somehow my Notification drawer is working now and battery drain has also reduced. No update just normal restarts and cache clean.
    The restart thing was told by an Xperia developer who told me to restart everyday for atleast a week after a firmware upgrade and then check the battery issue (in Xperia phone). I don't know if its due that effect but battery life has improved a lot on my OnePlus 3T.
    #78
  19. simonexm979
    Cupcake Dec 30, 2016
    #79
  20. charan.desuri
    Donut Dec 30, 2016
    charan.desuri , Dec 30, 2016 :
    My OnePlus 3T was heating abnormally and the battery drains very fast.
    My finger print sensor not working after some idle time
    #80
