Green display via OnePlus 7 Pro
  1. Abhijeet313
    Donut Aug 30, 2021
  2. BeingIncog
    Nougat Aug 30, 2021
    BeingIncog , Aug 30, 2021 :
    if it's hardware issue, which is likely to be... doesn't show in screenshots.
    nerdkabir, Artemus and Abhijeet313 like this.
  3. BeingIncog
    Nougat Aug 30, 2021
  4. Abhijeet313
    Donut Aug 30, 2021
  5. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Aug 30, 2021
    nerdkabir and Abhijeet313 like this.
  6. Abhijeet313
    Donut Aug 30, 2021
  7. Artemus
  8. BeingIncog
    Nougat Aug 30, 2021
    reach out to nearby service center...
  9. nerdkabir
    The Lab² - Oclean X Pro Elite Reviewer Aug 31, 2021
    nerdkabir , via OnePlus 7 Pro , Aug 31, 2021 :
    Exactly what were you doing when this happened? Did you update your phone to latest OS? Pressed the display hard by mistake? Dropped it?
    also, no exposure to water recently?
    Abhijeet313 likes this.
  10. Abhijeet313
    Donut Aug 31, 2021
    Abhijeet313 , via OnePlus 7 Pro , Aug 31, 2021 :
    There is a problem of green screen whenever I lock the screen.
    It's been a long time since the phone was updated.
    Last updates - 01-06-2021
    Updated OS - 11.0.2.1
  11. nerdkabir
    Can you try this?
    Go to Developer options. Then tap Disable HW overlays. Shut down your phone. Turn it on after 5 minutes.
  12. Abhijeet313
    Donut Aug 31, 2021
    Not work !!
  13. nerdkabir
    Have you tried backing up your data, factory reset?
    If it still doesn't work, it may be a physical damage indeed. May be a liquid damage (moisture) or the connector cable has become loose.
  14. Abhijeet313
    Donut Aug 31, 2021
    Tomorrow I am going to the service center, let's see what they say .....I'm totally FucktUp bro......This is the worst nightmare of my life......
  15. B1634455026887
    Cupcake Oct 17, 2021
    B1634455026887 , via OnePlus 7 Pro , Oct 17, 2021 :
    Did your problem solved? I'm also facing same green tinge issue!! Sometimes it's green sometimes its normal since yesterday evening!! What to do? Any suggestions pls?
