Camera Grey spot on photo with factor 1.0
  1. D1626004896084
    Cupcake Oct 20, 2021
    D1626004896084 , Oct 20, 2021 :
    When taking pictures with my OnePlus 8T (Android-Version 11 / Oxygen OS 11.0.10.10.KB05BA) with factor 1 to 1.7 there is a greyish spot visible on all photos. Attached you see an example: photo taken of a blank paper and grey spot on right side of photo.
    Can this somehow be corrected?
    Thanks
  2. Gor.
    Lollipop Oct 21, 2021
    Gor. , Oct 21, 2021 :
    Hey there.
    Did you try cleaning the camera lens and do you have a plastic sticker/ lens protector applied on your lens? If yes, kindly remove it as that could be causing the issue.
    puccellino likes this.
  3. Tokolozi
    Most Original Avatar Oct 21, 2021
    Tokolozi , Oct 21, 2021 :
    Check if there isn't any dust inside your lens, usually you can see it looking at it in bright light.
