246
[GUIDE]Bugs/Fixes/Features/Rooting OOS 3.5.5/6/7/8(with screenshot and video tutorials)
Do you want me to make video on how to use these features or screenshots are ok?
  1. Yes, I want a video
    489 vote(s)
    74.8%
  2. No, I don't want a video
    165 vote(s)
    25.2%
  1. The Imp
    Ice Cream Sandwich Dec 22, 2016
    The Imp , Dec 22, 2016 :
    I would like to thank
    @rarog for pinning this thread
    @SoniaB for giving me guidance and advice on how I should start this thread.
    Without them this thread wouldn't be possible. They will also help me in maintaining the thread.
    To clear the confusion let me explain about the different oos versions that were released
    • 3.5.5- This was the first release but the update was stopped as many people were facing network issues. Thread link
    • 3.5.6- This was the hotfix released to solve the network drop issue. This version is being used by most of the people. Thread link
    • 3.5.7- Many people lost their imei when they downgraded from 3.5.5 to 3.1.0 using the downgrade tool. Hence oneplus team came up with a fix for that and dubbed it as 3.5.7. If you have lost your imei then please PM @Crystal Z. your build number and email address for a patch fix guide to be sent to you.
    So there were lot of new and interesting features were introduced in this update as i used Oneplus 3 for a long time so i know about most of the features that you might not find that easily so I thought to share this with you all I will show most of the new features that I know and will tell you how to do it with the help of screenshots and videos
    Features
    Note:- Click on the spoiler button to see the full guide.
    1. Data Firewall Option ( Links - Screenshots , Video )
      Choose how an app should access internet​
      • Go to Settings
      • Data Usage
      • In the top right corner you will see the icon a network bar with gear icon click on it
      • You will see all your apps
      • There are 4 options
        • Allow- Allow the app to use internet
        • Forbidden- Don't allow the app to use internet'
        • Wifi Only- App will use internet when wifi is on'
        • Data Only- App will use internet mobile data is turned on
      You can also do batch operation by going to apply to all option by this you don't have to choose for each and every app you can select one option option for all apps.
      Links
      Screenshots
      Video
    2. Clear All Apps Running in the Background ( Links - Screenshots , Video)
      • Go to settings
      • Advanced
      • Recent App Management
        • Normal Clear- The app will be cleared but it might still run in background.
        • Deep Clear- The app will be cleared from the background
      So when you click on the clear all button in recent menu then it apps will be cleared according to the way chosen.​
      Note
      When you go to recent menu you can see 2 signs in each app window a padlock and a cross if u click on padlock then when you click on clear all button then the app will not be cleared.​
    3. Set Data Usage Limit ( Links - Screenshots , Video )
      • Go to settings
      • Data Usage
      • Choose the SIM
      • Billing Cycle
      • Data Limit and Billing Cycle
      • You will see 2 fields where you can insert values
        • Data Usage Limit- When your data usage reaches that limit then it your mobile will tell you
        • Usage Cycle Reset Date- When your plan is renewed you can insert the date.
      Note
      In the billing cycle menu there is an option called "Auto Disconnect From Network" when you choose this option you will not be able to use your mobile data above the limit you have set.
      Links
      Screenshots
      Video
    4. How to take Screenshots ( Link - Screenshots )
      As you all know that in this update the power menu was changed and there is no option to take screenshot so there are two methods to take screenshot​
      • Method 1
        • Press Volume Down + Power Button
      • Method 2
        • Go to settings
        • Gestures
        • Three-Finger Screenshot
      By using this method you will be able to take screenshot by swiping your three fingers on the screen.
      Link
      Screenshot
    5. Change Tag Name "NEVER SETTLE" in Shelf ( Links - Screenshots , Video )
      • Go to shelf by swiping right on your screen
      • Long press where "NEVER SETTLE" is written
      • Change it to whatever you like
      Note
      You can also choose whether to display weather information in shelf or not by long pressing "NEVER SETTLE" tag name and turning off weather information.
      Links
      Screenshot
      Video
    6. Add Memo in Shelf ( Links - Screenshots , Video )
      • Go to shelf by swiping right on your home screen
      • Click on the "+" button
      • You will see an option called Memo click on it
      Now you can write notes some notes and refer to them in shelf​
    7. Add Manage Center in Home Screen & in Shelf ( Links - Screenshots , Video )
      In Manage Center you can see that how much battery is left, available storage, data remaining according to data limit set. By clicking on the specfic thing will lead you to the detailed setting.
      • Add in Home Screen
        • Long press on home screen
        • Widgets
        • Manage Center
      • Add in Shelf
        • Widgets
        • Manage Center
    8. How to put your phone in Vibration Mode ( Link - Screenshots )
      • Go to settings
      • Alert Slider
      • Silent
      • Enable Vibration
      So to put your phone in vibration do it by sliding your alert slider to the topmost position.
      Link
      Screenshots
    9. How to disable DOZE Mode ( Links - Screenshots , Video )
      Doze mode stops some apps in background when your phone is idle for a long time this leads to delay in notification in some time you will see notification when you turn on your phone​
      • Go to settings
      • About Device
      • Tap on Build Number 7 times
      • Go back to main settings
      • You will a new option just above system update i.e "DEVELOPER OPTION"
      • Turn On Developer Options if it is turned off.
      • You will find an option called Doze Mode switch it off.
    10. How to enable Game Mode ( Links - Screenshots , Video )
      This new feature came in this new update you can use this while playing games the phone will divert its resources to the game so as to improve the gaming performance​
      • Go to settings
      • About Device
      • You will find an option called "Game Mode" turn it on so as to use it.
      Note
      By turning on this mode your device can heat and battery consumption can be increased as game will use most of the resources.
      Links
      Screenshots
      Video
    11. How to enable Volte ( Link - Screenshots )
      • Go to settings
      • Sim & Network
      • Turn on the Volte option
      You will see a volte sign on your status bar.​
      Link
      Screenshots
    12. Separate Ringtone for separate SIM card ( Links - Screenshots , Video )
      • Go to settings
      • Sound
      • Phone Ringtone
      • There is an option called "Set ringtone for each sim card" turn it on
      Now after turning it on you will be able to set different ringtone for different SIM.​
    13. Change Default Applications ( Links - Screenshots , Video )
      • Go to settings
      • Apps
      • Click on the gear icon
      • Default Apps
      So if you have installed third party launcher and want to come back to oneplus launcher then select oneplus launcher in desktop.
      Links
      Screenshots
      Video
    14. Change Permissions ( Link - Video )
      • Go to settings
      • Apps
      • Click on the 3-dots on the top right corner
      • Show System (If you want to see the permissions of system apps)
      • Find the app which you want to change permission for
      • Click on it
      • Permissions
      Link
      Video
    15. App Lock ( Link - Video )
      • Go to settings
      • Security & Fingerprint
      • App locker
      • Choose the app that you want to lock
      Note
      Once you unlock the locked the app it will not lock again unless to switch off your screen. This is not a bug it was intentionally done by oneplus
      Link
      Video
    16. System UI Tuner
      System UI tuner is used when you want to make some changes in status bar like removing some particular icons that you see in the status bar​
      • Pull down the notification bar
      • Long press on the gear icon
      • Now when you go in settings you can see a new option called System UI Tuner
      Note
      To disable System UI Tuner​
      • Go to settings
      • System UI Tuner
      • Click on 3- dots on top right corner
      • Remove from settings.
    17. Night Mode
      By enabling this setting blue light will be reduced so that you can use mobile in dark it reduces strain in the eyes​
      • Method 1
        • You will see the night mode tab click on it to enable it
      • Method 2
        By using this method you will also be able to change how much greenish screen you want​
        • Go to settings
        • Display
        • Enable Night Mode
        • After you enable night mode you will see a slider you can use it to adjust the green color in the screen.
    18. Double tap on lock screen to turn off screen
      • Go to settings
      • Gestures
      • Enable Double tap to wake
      So now at lock screen tap twice to turn off screen.​
    19. Swiping with one finger and two fingers in notification bar
      When you swipe with one finger then you will see only 5 quick tiles and all your notifications and you will have to swipe again so as to see all the quick tiles.
      But if you swipe with two fingers then all the quick tiles can be seen therefore we don't have to swipe again.​
    20. Scheduled Power on/off
      This feature is very good as you can turn your phone off at a specific time and turn it on at specific time. Tested it two to three times and it works perfectly.​
      • Go to settings
      • Advanced
      • Scheduled power on/off
      • Do the settings according to your need
    21. Set Alarm and hear it even if your phone is turned off
      Most times we don't want to be disturbed while sleeping and want to turn off our phone but can't do so as we will not be able to hear alarm as our phone will be switched off but don't worry OnePlus came up with a new feature​
      • Go to clock app
      • Set Alarm
      • Click on the three-dots in the top right corner of the app.
      • Click on settings.
      • Enable "power off alarm"
      By enabling this you will be able to hear alarm even if your phone is turned on.​
      Note
      You will not be able to hear alarm if your phone has no battery left as the phone will not be able to boot up.​
    22. Flip to mute incoming call
      When a call is coming you can flip your device to mute so you will not hear ringtone but you can still pickup call.​
      • Go to settings
      • Gestures
      • Enable "Flip to mute" option
    Will keep on updating with more and more new features. And if I have forgotten about any feature then please tell me.
  2. The Imp
    Credits- @Spannaa for all the mirrors of official OTA's and for the SuperSU link.
    @Funk Wizard & @Naman Bhalla for rooting, nandroid and EFS backup guide.
    @Lord Boeffla for latest modified SuperSU.
    The SuperSU and TWRP are compatible with 3.5.5/6/7/8.
    1. SuperSu 2.79 modified TWRP flashable zip
    2. TWRP custom recovery
    3. Oxygen OS official recovery
    3. Rooting, nandroid & EFS backup guide
    4. Mirror for official oxygen OTA's.
    5. How to flash custom ROM's and Kernel's (XDA Link)
    6. Unbrick guide
    Note:- Use SuperSU and TWRP that are given above as in some of the threads that are given above. It might be possible that old versions of SuperSU and TWRP might be mentioned which might be incompatible with the latest OS.
    Extras (OnePlus Apps)
    1. Music
    2. File Manager
    3. Weather
    4. Sound Recorder
    5. Community App
    Download Link
    Xposed Guide (3.5.5/6/7/8 compatible)
    Note- Take nandroid and efs backup before installing xposed because if you ran into problem then you can revert back easily.
    Prerequisites
    • Custom Recovery (TWRP link and guide above)
    • SuperSU (link and guide above)
    Guide
    • Install this file via custom recovery
    • Install this apk file like you normally do
    • Install whatever modules you want
    If you want to uninstall xposed completely from your device then
    • Remove all the modules
    • Flash/Install this uninstaller via the custom recovery
  3. The Imp
    Misconceptions about the new features
    These are not bugs these features were intentionally introduced by OnePlus in OnePlus 3 Open Beta program and was ported in Oneplus 2
    1. App Lock Bug- The App lock bug some people reported that when they unlock the app once it will remain unlocked until screen is switched off. This is not a bug it was intentionally done.
    2. Volume not lowering to 0 or not able to put the phone in vibration- I talked with lots of OnePlus 3 users and used Oneplus 3 myself this is not a bug it was intentionally done by OnePlus Developer Team. And you can put your phone to vibration by following the guide in #1 post
    jogerj, sanketzalak, kaihp and 8 others like this.
  4. The Imp
    Bugs that I am/was facing :-
    1. Pocket Mode not working I can still unlock my phone when my phone is in my pants.
    Status-Bug reported and contacted by oneplus team.
    2. When hotspot is turned on via settings then in quick tiles the hotspot icon lightens up but a slash can still be seen.
    Bugs that others are facing but I am not facing them
    1. Night Mode not working
    2. Color Balance not working
    3. Not able to see messages
    4. Facing problems with contacts
    5. Volte not working
    These issues can be solved by resetting your phone. So first take backup of everything and then reset. If that doesn't work then there is a long process. Downgrade to 3.1.0 then to 3.1.1 via the method given in update thread. Then update to 3.5.6 via OTA this will solve all the problems except the bugs that I am facing.
    Report your bugs on the link given below as developers will hear you more quickly if you write in the bug report section .They might not be able to see your posts in general threads
    here is the link to report bugs
    https://forums.oneplus.net/feedback
  5. dbg.alex
    Donut Dec 22, 2016
    Ranjithsmart and The Imp like this.
  6. The Imp
    Thnx share this thread more new features will be added
  7. Dabzz
    Gingerbread Dec 22, 2016
  8. The Imp
    You can download opera vpn app from playstore then you can change region to germany or canada.
    Go to system update refresh it you will get your OTA
    hope this solved your problem
  9. Dabzz
    Dabzz , Dec 22, 2016 :
    Ok thanks.
    F_Nikhil_Bhute_LFws likes this.
  10. Harshal jadhav
    Froyo Dec 22, 2016
    The Imp likes this.
  11. nuxi-popuxi
    Cupcake Dec 23, 2016
    nuxi-popuxi , Dec 23, 2016 :
    sim card not found after Upgrade to 3.5.5.
    Provider: Vodafone Germany
    Device: One plus 2
    Sim card worked before upgrade. After upgrade sim card is not found any more.
    Tried the following steps without success:
    - searched for Provider and tried to connect to network (sim settings)
    - activated sim in settings
    - switched device off/on
    - deleted network settings
    - removed / inserted sim
    !!!!!!!! Please resolve this issue quickly!!!!!!!
    After this upgrade I cannot make/receive phone calls anymore and I cannot use mobile Internet.!!!!!!!
  12. shauryamago12
    Eclair Dec 23, 2016
    shauryamago12 , Dec 23, 2016 :
    How can I change wifi without going into wifi settings? I used to be able to quickly toggle it with the small arrow in the notification bar...
  13. Browncc45
    Browncc45 , Dec 23, 2016 :
    Is there a way to tell when VoLTE activates? I want it for t-mobile US but info is nowhere to be found yet
  14. arifmuhammed
    Froyo Dec 23, 2016
    rixonit and G_Anjan_Kumar_RhVx like this.
  15. G_bobby_planb_kIAA
  16. G_Satish_Chaubey_QjoV
    Donut Dec 23, 2016
    Ronak_Mangalwedhekar likes this.
  17. krupal kadu
    Donut Dec 23, 2016
    krupal kadu , Dec 23, 2016 :
    did oneplus 2 got f2fs storage in OOs 3.5.5 ?because oneplus 3 have it in 3.5 build .if yes then it will make oneplus 2 very much faster .
  18. The Imp
    Ice Cream Sandwich Dec 23, 2016
    The Imp , Dec 23, 2016 :
    Buddy there is no working method so that these problem can be fixed many users are facing problem with their network you can report the bug in here
    and if you are facing network drop issues then click on the star on this thread
    https://forums.oneplus.net/threads/frequent-network-drops-after-oos-3-5-5-update.480581
  19. arifmuhammed
    Froyo Dec 23, 2016
  20. braveheart14283
