246
[GUIDE]Bugs/Fixes/Features/Rooting OOS 3.5.5/6/7/8(with screenshot and video tutorials)
Do you want me to make video on how to use these features or screenshots are ok?
  1. Yes, I want a video
    489 vote(s)
    74.8%
  2. No, I don't want a video
    165 vote(s)
    25.2%
  1. Ambatti
    Eclair Jan 2, 2017
    Ambatti , Jan 2, 2017 :
    Thanks for the prompt. But one thing i would like to write is that i had encrypted the phone long back and did receive the 3.5.5 update and successfully installed. Then will the upgrade 3.5.6 happen as 3.5.5. Pls guide.
  2. Ambatti
    Eclair Jan 2, 2017
    Apart from this i do not have any issues apart from network dropping frequently and battery issue.. Thia is supplement to my above query.
  3. Ambatti
    Eclair Jan 2, 2017
    My another query whether good number of one plus two have received the update 3.5.6 or still majority are yet to get the same.
  4. Bibin Alexander
    Froyo Jan 2, 2017
    Bibin Alexander , Jan 2, 2017 :
    After the 3.5.6 update, it is. But still no signs of VOLTE functioning.
  5. Afc_lee70
    Cupcake Jan 2, 2017
    Afc_lee70 , Jan 2, 2017 :
    Anyone know how to apply an icon pack now. When you long hold on home screen it doesn't give the settings option anymore. Apologies if I've missed if this has already been asked.
  6. ariblaze
    Jelly Bean Jan 2, 2017
    ariblaze , Jan 2, 2017 :
    Click in 3 dots and then reset app preferences. Then set all the permissions from the beginning.
  7. ariblaze
    Note : Before trying out the below steps, do backup your data and everything else (contacts, sms, etc.). The downgrade process is provided by @Tony L.
    This downgrade process will erase all data from your phone, please perform a full backup of your data before you start downgrading. Please ensure the device has enough power or charged in before downgrading. Basic functions will be affected if you skip step 3 and perform step 7 immediately.
    Steps:
    1) Download 3.1.1 Intermittent Version and 3.1.0 Stable Version and copy them onto the phone’s directory. (Example: Storage/Internal Storage/Download)
    2) Power off your phone and enter Recovery Mode by pressing the Power and Volume - button together for 3 seconds.
    3) Choose English > Install from local > Choose OnePlus2Oxygen_14_OTA_021_all_1610121102_wipe_9505656273ba4203.zip from the phone’s directory. (Example: Storage/Internal Storage/Download)
    4) Wait for the flashing process to complete. Do not cut off power and do not interrupt until the process is completed.
    5) After the flashing, choose “Reboot” and device will restart.
    6) Repeat Step 2.
    7) Choose English > Install from local > Choose OnePlus2Oxygen_14_OTA_020_all_1608262242_44a55e674a2b4bf6.zip from the phone’s directory. (Example: Storage/Internal Storage/Download)
    8) After the flashing, choose “Reboot” and device will be downgraded to 3.1.0.
    Once the downgrade is complete, visit this link https://forums.oneplus.net/threads/mirrors-for-official-oxygen-os-roms-and-ota-updates.387615/ and download the Oxygen OS 3.5.6: OnePlus2Oxygen_14_OTA_027_all_1612271635.zip and then install it by going into recovery mode (press power button + volume down) and Choose English > Install from local > Choose OnePlus2Oxygen_14_OTA_027_all_1612271635.zip and once installation is complete, reboot the phone.
  8. Bibin Alexander
    Froyo Jan 2, 2017
    Thanks, mate. So to get VOLTE is it necessary to perform a downgrade? Won't the reboot from the recovery mode work?
  9. ariblaze
    Did not work for me. Had to downgrade to 3.1.0 and then install 3.5.6 and only then it started working. I bugged a lot of people including @SoniaB and at last @coolrevi suggested this and it worked.
  10. Dinesh.D
    Cupcake Jan 2, 2017
    Dinesh.D , Jan 2, 2017 :
    I don't have nay volte option in my sim and network settings,
    and I'm running on v3.5.6 .
    what to do???
    I updated via opera mini VPN.....
  11. G_shubham_goenka_LveE
    Cupcake Jan 2, 2017
  12. Benjamin Venugopal
    Cupcake Jan 2, 2017
    Benjamin Venugopal , Jan 2, 2017 :
    With the latest update of OnePlus 2 OS 3.5.6 when the phone is connected to the charger the icon does not change from % to lightening indicating the phone is charging
    2. There's a lot of heating issue
    3. Battery Drains out quickly. My phones battery does not last more than 4 hours from 100% charge.
  13. amyodov
    Eclair Jan 2, 2017
    amyodov , Jan 2, 2017 :
    I used to look at the next-alarm-time by pulling down the notification bar as well; but now, with 3.5.6, the alarm time IS NOT displayed there, no matter if I seed the time using Gentle Alarm or Google Clock app (is is the stock one?). But if I manually enable the screensaver with clocks, it will display the next alarm time, and now it is the only place in the interface too see them. Seems pretty strange, probably worths a bug?
  14. 9552722777
    Cupcake Jan 2, 2017
  15. G_shubham_goenka_LveE
    Cupcake Jan 2, 2017
    G_shubham_goenka_LveE , Jan 2, 2017 :
    for the notification light you can do three things
    1.enable notification light from led notification.
    2.dial *#808# and check led notification
    3.if all are set and u are using whatsapp, check if the led light. If it is white change its colour to some other colour.
  16. G_shubham_goenka_LveE
    Cupcake Jan 2, 2017
    see no option for ok.
  17. mayday007
    Cupcake Jan 2, 2017
    mayday007 , Jan 2, 2017 :
    No battery shortcut in drop down menu is a kind of bummer :(
    Long press on data short cut key now directly takes to menu. No data used graph. It is same with Hotspot too.
  18. NatilaZ
    Cupcake Jan 2, 2017
    NatilaZ , Jan 2, 2017 :
    Has anyone else had problems with connecting to WiFi since the update?
  19. jmarks
    Honeycomb Jan 2, 2017
    jmarks , Jan 2, 2017 :
    Hello @100196, I have de same issue as @amyodov. I do not see any information about the next alarm when I pull down the notification bar. I set alarm by stock app. It will be a matter of settings?
  20. bestlands
    KitKat Jan 3, 2017
