29
[GUIDE] Convert Your OnePlus One Into Universal Remote Control!
  1. rbagdai
    The Lab - OnePlus 8T Reviewer Jun 15, 2015
    rbagdai , Jun 15, 2015 :
    Hey guys, this is an ultimate way to turn your OnePlus One into an Universal Remote Control that can control a DSLR, TV, A/C, STB and a lot more objects which use IR signals.
    UPDATE 8th Feb 2016:
    YAY! new video tut! IK it's very late but yeah :D)
    WRITTEN TUT:
    Step 1 You have two options here:
    • Build it yourself! Check this video out:
    Here is my One with my own circuit.
    I have ordered the product but not yet delivered thus, I had to make it on my own!
    I know the photos aren't good quality. Of course, because they aren't taken using a OnePlus One :D
    UPDATE: the IR jack is delivered:
    UPDATE (25 July 2015): I got a better IR jack as the previous one didn't function as good as I expected. BETTER IR JACK BUY HERE
    Name of new IR jack: Kiwik
    This is a better one and has it's own native app! This works awesome! You don't need to refer to steps 2-5 if you are buying Kiwik. The Kiwik app is very easy to use and very self explanatory. If you don't understand how to use it, read the steps below for ZaZaRemote. Both apps are very similar, only difference is that Kiwik app works better and requires Kiwik IR Jack
    These steps are only for the old accessory or if you made the IR jack on your own.
    Step 2 Download this app which will enable sending IR signals: ZaZa Remote
    Next, make sure your accessory is attached.
    Step 3 Then, continue by clicked "Add Remote".
    Step 4 If you've connected the IR jack, the device is detected and you are in the application. Then select the gadget you want to control.
    Step 5 Click the power off button. If it works, click "Has Response" and if it doesn't click "No Response" [This will take you to other IR signal]
    The App will show only sone signals at first, if none work, the app will increase the amount of signals which you can try out!
    Once you finally set it up, you can now control your devices with your OnePlus One! :)
    Happy To Help :)
    Also if you try it out, don't forget to leave your feedback :)
  2. nusantara
    Gingerbread Jun 15, 2015
    sagarvora407 and rbagdai like this.
  3. nchaitanyareddy
    Ice Cream Sandwich Jun 15, 2015
    rbagdai likes this.
  4. Takendown
    Jelly Bean Jun 15, 2015
    Takendown , Jun 15, 2015 :
    Will give it a wiz. Looks cool. I can now screw with people from a remote they know nothing about! :D
    Ceasedd, H1m@nshu and rbagdai like this.
  5. giaur500
    giaur500 , Jun 15, 2015 :
    I have similar one, but connected to micro usb, not jack. Works like a charm.
    mu1zz786 and rbagdai like this.
  6. LostPorcupine
    KitKat Jun 15, 2015
    LostPorcupine , Jun 15, 2015 :
    Why a link to download a zip file from another site instead of from Google Play?
    https://play.google.com/store/apps/details?id=com.tiqiaa.remote&hl=en
    rbagdai likes this.
  7. rbagdai
    Takendown and LostPorcupine like this.
  8. amartens181
    KitKat Jun 15, 2015
  9. Baymax
    Starting Point Expert Community Expert Jun 15, 2015
    LostPorcupine and rbagdai like this.
  10. LostPorcupine
    KitKat Jun 15, 2015
  11. Baymax
    Baymax , Jun 15, 2015 :
    I got both the micro USB and audio jack one in case one doesn't work.
  12. HD08
    Donut Jun 15, 2015
    HD08 , Jun 15, 2015 :
    This is not possible as oneplus one hasn't got an ir blaster in it...
  13. KrishPlusOne
    KrishPlusOne , Jun 15, 2015 :
    Read the actual post before replying.. He uses a seperate IR accessory
  14. KrishPlusOne
    sarang Bakshi likes this.
  15. HD08
    Donut Jun 15, 2015
    srry didnt see that.....
  16. firefly5
    firefly5 , Jun 15, 2015 :
    Can the same software deal with both the audio jack and USB port versions?
  17. marcvento12
    marcvento12 , Jun 15, 2015 :
    The video isn't very clear...but it will be good to try
    EDIT: i'm not very good making these things...if anyone can help?? THAANKS
  18. rbagdai
    The video isn't mine.You could buy the IR jack as listed above :)
    marcvento12 likes this.
  19. giaur500
    I have not tried jack audio, but usb version bought from ali works on my oneplus without any problem, including ir codes learning. I can use my phone as a remote for any device I want to
  20. Baymax
    Okay
