21
[GUIDE FOR MAC] How to Unlock Bootloader, Install Custom Recovery & Root (Macbook Pro)
  1. selvagukan
    Froyo May 9, 2015
    selvagukan , May 9, 2015 :
    I am a mac user.I unlocked the boot loader and installed the TWRP lastest one through ADB .. When i reboot into recovery i am not getting TWRP , CM recovery is loading
    Pls help me.
    @Funk Wizard @vigneshvar1
  2. Funk Wizard
    Lollipop Moderator May 9, 2015
    Funk Wizard , May 9, 2015 :
    Looks like your flash was unsuccessful, uncheck update CM recovery from developer options and flash twrp again
  3. selvagukan
    Froyo May 9, 2015
    First time itself,i unchecked it. unchecked the CM recovery and done flashing 4 times...No use...still CM recovery is coming. @Funk Wizard
  4. Funk Wizard
    How are you flashing it..
  5. selvagukan
    Froyo May 9, 2015
    First checked ADB in settings->then unlocked Bootloader(phone completely erased)->rebooted,Enabled ADB,disabled CM recovery,ADB command for recovery with Recovery img file->restarted.... then rebooted into recovery but CM came ...:(:(:(
  6. selvagukan
    Froyo May 9, 2015
  7. Funk Wizard
    Buddy check the downloaded image again may be a bad download. All u have to do is download the image again reboot into bootloader and
    ./fastboot flash recovery (Drag & Drop the recovery img on the Terminal) Hit Enter Done :D
    ./fastboot reboot
    The device would reboot & Now your device has custom TWRP Recovery
  8. selvagukan
    Froyo May 9, 2015
    i ll tried it..Can i delete the recovery using ADB command and loaded it again..Will it be good to do like this?
  9. Funk Wizard
    Yes u can try that and reflash
    selvagukan likes this.
  10. selvagukan
    Froyo May 9, 2015
    Funk Wizard likes this.
  11. Funk Wizard
    Welcome buddy.. I just use stock settings on synapse just UC and UV slightly nothing over the top
  12. Autre31415
    Jelly Bean May 21, 2015
    Autre31415 , May 21, 2015 :
    @Funk Wizard I'm have the same problem, I've attempted to install the twrp recovery several times now but when rebooting into recovery it's still CM, it's unchecked and everything. Not sure how to proceed.
  13. Funk Wizard
    Lollipop Moderator May 21, 2015
    Funk Wizard , May 21, 2015 :
    After flashing twrp.. U have to manually reboot into recovery like a force reboot to recovery by pressing Vol down and power together
  14. Autre31415
    Thanks, that worked perfectly!
  15. Funk Wizard
    Lollipop Moderator May 22, 2015
  16. metalGearSumo
    Donut May 26, 2015
    metalGearSumo , May 26, 2015 :
    I followed everything as you mentioned till flashing TWRP and everything went fine, no error but When I do this it opens CM recovery mode
  17. metalGearSumo
    Donut May 26, 2015
    What do you mean by "delete the recovery using ADB command" . I'm also facing the same problem and don't know how to solve it.
  18. Funk Wizard
    Lollipop Moderator May 26, 2015
    Funk Wizard , May 26, 2015 :
    #38
  19. selvagukan
    Froyo May 27, 2015
    #39
  20. metalGearSumo
    Donut May 27, 2015
    #40
