Hello Everyone, Today The Cm12s OTA was released and many people are excited to Flash it and use it on their Device
... Me As a Oxygen User Was Bored Of It As it is featureless and wanted something better like cm12s which had many features and looks promising... So without further talks i will write a guide to flash cm12s (As i myself did) :-
1. Download cm-12.0-YNG1TAS0YL-bacon-signed.zip
https://www.androidfilehost.com/?fid=95916177934554833
2. After Downloading The Zip paste it to ur phone.
3.Go To Settings -> About Phone -> Tap Build Number -> Developer Options Should Be Unlocked , Then Go To Developer Options And Check Enable USB Debugging
4.I Used a App Flashify To Install Latest TWRP Recovery 2.8.6.0 you can just download it from their website and flash it ->
http://twrp.me/devices/oneplusone.html (Note : Flashify App Can Be Used On Rooted Devices Only)
(Important.. Backup Everything Before.. Just In Case Anythin Goes Wrong)
5.Now Power Off Ur Phone And Get into Recovery Mode (Vol Down + Power)
6.Now Go To Wipe -> Advanced Wipe -> Check Dalvik Cache,Cache , System ,Data (Leave Internal Storage and USB OTG unchecked)
7.After Wipe Is Complete. Go Back Select Install -> Select cm-12.0-YNG1TAS0YL-bacon-signed.zip ... Installation Process will begin Then Reboot
(It Will Ask You To Install SuperSU or not my advice you should as you dont lose warranty even if you root rest is your choice)
It will reboot and you will see the new CYANOGEN logo it takes 5 - 6 minutes to boot for the first time ... After Reboot Complete Just Complete The Sign Ups and Reboot Again.
This is What I did and I have successfully Flashed CM12S On My Phone... Thank You
