151
[GUIDE] [General] How to make LTE faster and fixes all your problems!
  1. aleep
    Cupcake Feb 6, 2017
  2. bestlands
    KitKat Feb 6, 2017
    bestlands , Feb 6, 2017 :
    Yea sure, you can do it, im not exactly 100 percent sure about the chinese varient of the opo, its been so long, but im sure it works.
    pluscat likes this.
  3. Siddharth.Life
    Gingerbread Feb 10, 2017
  4. Isaact94
    Cupcake Jul 12, 2017
    Isaact94 , Jul 12, 2017 :
    I don't see an option for LTE/GSM auto (PRL). Nothing with LTE and GSM in the same.
    My phone started not taking or making calls about a week or so ago. This only seems to happen when LTE is preferred; when 3g is preferred it is able to make and take calls. Any ideas?
    Opo at&t usa
  5. PeterColpaert
    Froyo Jul 17, 2017
    PeterColpaert , Jul 17, 2017 :
    I have the exact same problem: people who call me go straight to voice mail, I get a text message later that someone called me, but no missed calls on my device. This happens only when I select "LTE preferred", not when I'm on 2G. For some reason, 3G doesn't give me any signal whatsoever.
    I already tried flashing all possible radios, did a factory reset, flashed Franco Kernel, but nothing helps. OP support tells me it's the network and suggests that I return my phone for repair (paid, yea right). My carrier claims it's the phone.
    One friend of mine has the exact same phone/ROM, but on a different network -> no problems
    One other guy I helped flash Lineage has the same phone/ROM on the same network -> no problems
    OPO running latest LineageOS 14.1, carrier Telenet in Belgium.
  6. Tejas Gujar
    Gingerbread Jul 28, 2017
  7. bestlands
    KitKat Sep 4, 2017
    bestlands , Sep 4, 2017 :
    Very very strange, If your on att, there is no volte on unlocked phones so calls can't be made via lte, so what every other carrier does if your phone doesn't have volte is they make calls of hspa or 2g network. So thats why you can only make calls over 3g preferred. I would flash a rom or something to see why you don't have those settings.
  8. bestlands
    KitKat Sep 4, 2017
    Im glad it helped you, thanks
    Tejas Gujar likes this.
  9. bestlands
    KitKat Sep 4, 2017
    Look at my post above the other one, I can tell you why its happened but I can't tell you why your phone isn't showing the settings. I currently don't even own a OPO anymore so i can't be any help there. As you mentioned it works for some and for you it doesn't, maybe something changed that im not aware off. Sorry if i couldn't be able help there.
  10. PeterColpaert
    Froyo Sep 4, 2017
    PeterColpaert , Sep 4, 2017 :
    Being more and more convinced that it's hardware, not software, I took the plunge and ordered myself a new phone. Not a OnePlus this time, because it's become very expensive over time...
  11. bestlands
    KitKat Sep 5, 2017
    bestlands , Sep 5, 2017 :
    Yea i know, its kinda ridiculous, wanting to go back to the opo price days. I mean phones are probably planning on going up and the new mid range is 600 to 700 while low end will be 400 or 300 and high end flash ship will be thousand, Soon we will be getting into pc gaming territory.
  12. PeterColpaert
    Froyo Sep 5, 2017
    PeterColpaert , Sep 5, 2017 :
    I got myself a Xiaomi Redmi Note 4 Global - similar or superior to the OPO except for the lack of NFC.
  13. bestlands
    KitKat Sep 6, 2017
    bestlands , Sep 6, 2017 :
    IM currently looking right now at the lg v30 or essential phone, which ever gets me the best deal maybe my carrier.
  14. davidmichaels
    Cupcake Jun 26, 2018
    davidmichaels , Jun 26, 2018 :
    Hey i was having some issue in activating these settings that you gave, but i found a smaller guide than yours and tried to solve this issue by combining steps of your and another at&t apn settings guides, it helped me out really well ;):D
    Thank You !.
  15. Theinsane1990
    Cupcake May 26, 2019
    Theinsane1990 , May 26, 2019 :
    So I have a unlocked S10e from Verizon and my carrier is MetroPCS. These are my tests. Somehow global beat everything but I'm gonna stick with LTE/CDMA[​IMG]
  16. Theinsane1990
    I was outside my house for the readings above..
    Now I'm in my room in the basement and from bottom to top, is GLOBAL, LTE/CDMA, LTE/GSM/UMTS
    Weird how LTE/CDMA had no upload.. but the Download is good...
    Idk what one to use. Lol
  17. W1571970663109
    Cupcake Oct 25, 2019
    W1571970663109 , Oct 25, 2019 :
    I pmed.. I think all this helped only problem is my call receiving or outgoing
  18. W1589375505315
    Cupcake May 31, 2020
    W1589375505315 , May 31, 2020 :
    I had the same issue with my tmobile oneplus 7t. Fixed it by dialing *#*#4636#*#* then phone information -> then selecting under preferred network type: "GMS/WCDMA/LTE (PRL)". the default that it was set to that was causing me issues was "LTE/TDSCDMA/GSM?WCDMA"
    thank you so much for this tutorial !!!!!!
