76
[Guide] Get Android P's Digital Wellbeing feature on your OnePlus phone!
  1. FlixbusLennart The Lab - OnePlus 6 Reviewer May 3, 2019
    FlixbusLennart, May 3, 2019 :
    Possible when you go the root route
  2. michri69 Cupcake May 29, 2019
    michri69, May 29, 2019 :
    Hello FlixbusLennart, hello Forum,
    DW does a good job on my Op5 oxi-beta.
    2 points that bother me a bit I would like to mention here:
    1. after activating the grey mode in the evening, it often turns off, so that the display is colored again when i unlock the device... what could be the reason for this, or what smartphone function does it have?
    2. The icon leading to DW in the settings is only a thick blue dot. Could this be because the Magisk version is a very early beta and can you do something about it? - I know this is only cosmetic ;)
    Greetings, Michri
    FlixbusLennart likes this.
  3. FlixbusLennart The Lab - OnePlus 6 Reviewer May 29, 2019
    FlixbusLennart, May 29, 2019 :
    Hi and welcome!
    1. Grey mode can be tricky, it works on OP5 line, does not have any effect on the OP6 line - and also doesn't like Night Mode. My best bet is that Night Mode (where you screen gets a blue light filter) also toggles Grey Mode somehow.
    2. That could be the case, but I think that there is no newer flashable zip that might have any fix for the icon. It's good, at least, that Oxygen settings have a fallback option when there is no icon. Might be possible in the future tho, as I see OP7 Pro having DW included. Let's hope for the best!
  4. soder Eclair Jun 1, 2019
    soder, Jun 1, 2019 :
    Is there still no way to get the wind down and grey scale function to work on the OP6T?
    Root, magisk or any other way?
    /Söder
  5. FlixbusLennart The Lab - OnePlus 6 Reviewer Jun 1, 2019
    FlixbusLennart, Jun 1, 2019 :
    Hey,
    I think wind down, the part where it enables DND by itself, is possible using the root way and maybe even rootless. The other part of it, where the screen goes to grayscale - I haven't found a solution yet. For that, you might want to use reading mode, which does the same as grayscale in wind down.
    /Lennart
  6. benjg Donut Jun 1, 2019
    benjg, Jun 1, 2019 :
    Has anyone tried this on the OnePlus 3T yet since pie is out now?
    Otherwise I will test it now
  7. FlixbusLennart The Lab - OnePlus 6 Reviewer Jun 1, 2019
    I'd love if you could test it out, thank you!
  8. benjg Donut Jun 1, 2019
    Can confirm that this also works for OnePlus 3/3T!
  9. FlixbusLennart The Lab - OnePlus 6 Reviewer Jun 1, 2019
    Oh yeah yeah
    Root or non-root?
  10. benjg Donut Jun 1, 2019
    FlixbusLennart
    Oh yeah yeah
    Root or non-root?​
    root method, i don't know a about non-root
  11. FlixbusLennart The Lab - OnePlus 6 Reviewer Jun 1, 2019
    Alright, thanks for your contribution!
    benjg likes this.
  12. benjg Donut Jun 1, 2019
    you're very welcome!
  13. one_fom Cupcake Jun 17, 2019
    one_fom, Jun 17, 2019 :
    NON ROOT mode is working on my OnePlus 3T :D
    Launch that activity on QuickShortcutMaker and enable app on the drawer.
    Thanks for this guide!
  14. E1560619755798 Donut Jun 21, 2019
    E1560619755798, Jun 21, 2019 :
    Unfortunately. I did everything to not make this appear as if it were just another "When Android P sir" thread. Well, maybe some people might still find this one ^^
