200
[GUIDE] How to go from Oreo to Stock Nougat
  1. dsmonteiro
    Community Consultant Staff Member Oct 20, 2017
    dsmonteiro , Oct 20, 2017 :
    Howdy!
    EDIT: This guide was originally made to revert from Beta Oreo to stock Nougat but the steps in this guide also work for Stock Oreo.
    Seems like some of you are struggling to get back to Stock Nougat after trying Oreo Beta. This guide's job is to help you in that process.
    Note: Please note that you will lose your data after finishing this process. This is a mandatory step to get back to Stock Oxygen OS. If you decide to stay with Nougat Open Beta you will only lose partial data (The build will wipe app and cache data, but Internal Storage will be saved (ie: pictures and files)).
    Disclaimer: I don't have a OnePlus 3 to test this guide with but these are the steps you need to take. In the event that something goes wrong, I'm not responsible for it.
    Files you'll need:
    • OnePlus 3:
      • OnePlus 3 OBT 24 (Special build): Here | Mirror: Here.
      • OnePlus 3 Stock 4.5.1: Here | Mirror: Here.
    • OnePlus 3T:
      • OnePlus 3T OBT 15 (Special build): Here | Mirror: Here.
      • OnePlus 3T Stock 4.5.1: Here | Mirror: Here.
    Instructions:
    1. Backup everything you need. You will lose data after this process is done.
    2. Download the files above for your OnePlus 3 / 3T. This are the official files directly from OnePlus.
    3. Copy the two files to your phone's internal storage.
    4. Reboot your phone into recovery mode. To do this, shut down your device and turn it back on while holding the power and volume down buttons simultaneously.
      1. Choose “Install from Local”
      2. Install the Special build (O2N_OBT_15801_OXYGEN_SIGN_wipe.zip)
    5. Reboot. After this step you'll be on Nougat Open Beta 24 / 15. You can choose to stay with this ROM or revert completely to stock Oxygen OS. Continue with the steps below to fully revert to Stock Oxygen OS.
    6. Reboot your phone into recovery mode again.
      2. Install the Stock 4.5.1 for your OP3 / 3T (the other file).
      3. Select Wipe data and cache > Factory reset and tap: Yes".
    7. Reboot. At this point your phone will be fully wiped and on Stock 4.5.1. You'll need to go through the initial setup and redownload / copy files to your phone again.
    Please leave your feedback. Cheers and I hope this helps!
  2. Sun90
    Starting Point Expert Community Expert Oct 20, 2017
    Sun90 , Oct 20, 2017 :
    Good going.
    Bookmarked.
    Edit: would help a lot if this can be pinned for some time .
    girishp, f00tbaLL, Punk_69 and 19 others like this.
  3. VaibhavBhargava
    Lollipop Oct 20, 2017
  4. meatandy
    Oreo Oct 20, 2017
    meatandy , Oct 20, 2017 :
    You clearly saw a need for this thread in the coming months , thanks for your efforts.
    pa5t1s, f00tbaLL, dineshsp04 and 10 others like this.
  5. varma246
    varma246 , Oct 20, 2017 :
    More spoon feeding, EH? :rolleyes: jk. But as usual people don't search!
    Nice thread with Needful information for those who wanna rollback to Nougat.
  6. dsmonteiro
    Well, at least until the Beta becomes stable enough. From the looks of it, it's not there yet.
    And it's easier to make the thread than to say the same thing over and over again.
  7. Intruder71
    Intruder71 , Oct 20, 2017 :
    S
    Shame they never search which means they'll never see it... Good idea well written but will be ignored sadly..
  8. dsmonteiro
    Well, in that case I just need to link them to this thread. ;)
  9. Intruder71
    Your going to be busy good luck...
  10. Sun90
    Yeah.
    Some guiding them and some chiding them;)
    Intruder71 and meatandy like this.
  11. meatandy
    Oreo Oct 20, 2017
    This thread should have a sticky!! But that's not my decision.
    atenaa, dsmonteiro and Sun90 like this.
  12. Sun90
    Pick one for the mods atleast;)
  13. theshinybeast
    Marshmallow Oct 20, 2017
    theshinybeast , Oct 20, 2017 :
    Is this meant to keep you busy and out of trouble?:p
    Nice thread.Bookmarked it for future referals.
  14. dsmonteiro
    Well, I have to behave sometimes...
  15. VaibhavBhargava
    VaibhavBhargava , Oct 20, 2017 :
    Crazy glue
    Well, we just have to spam this link in their spam thread.
    Praty_28 and Sun90 like this.
  16. F_Kseng_Roy_vtzR
    Cupcake Oct 21, 2017
  17. dsmonteiro
    Community Consultant Staff Member Oct 21, 2017
    dsmonteiro , Oct 21, 2017 :
    No, you need one to send the fastboot command.
    theshinybeast and Sun90 like this.
  18. F_Kseng_Roy_vtzR
  19. Sun90
    Starting Point Expert Community Expert Oct 21, 2017
    Sun90 , Oct 21, 2017 :
    Why isn't this sticky yet?
    theshinybeast likes this.
  20. S1508578126038
