201
[GUIDE] How to go from Oreo to Stock Nougat
  1. Rohan Yuttham
    Cupcake Dec 20, 2018
  2. Artizanoil
    Eclair Dec 22, 2018
    nombre74 likes this.
  3. DrNinjaa
    Cupcake Dec 23, 2018
  4. Artizanoil
    Eclair Dec 23, 2018
  5. revonomics
    Eclair Feb 11, 2019
    revonomics , Feb 11, 2019 :
    Will This work if im on the OxygenOS OP3T_02_BETA_30 version on my OnePlus 3T??.
    And Android P open beta update is not available for OP3T now right?
    Thanks in advance.
  6. Bharanivijay
    Honeycomb Feb 13, 2019
    Bharanivijay , Feb 13, 2019 :
    OnePlus has closed the open beta builds for OnePlus 3/3T. There is no point of waiting for an Open Beta Pie update. You should have reverted to stable build long ago.
  7. Dheeraj Menon
    Gingerbread Feb 16, 2019
    Dheeraj Menon , Feb 16, 2019 :
    FullMetal98
    Can you please the update the files for the OP3T OBT 15 special build. This is an emergency. Please respond ASAP.
    Thanks in advance
    I want to switch from Open Beta 30 to Oxygen OS 5.0.6
    When I download the file and place it in local storage and try to upgrade form the recovery menu it shows as failed.​
    Did you try to flash the current OOS 5.0.8
    All you need to do is
    1.Download the OOS 5.0.8 and place in root folder
    2.Reboot to recovery
    3.Click on"Install package from internal storage"and click on the ROM
    file
    4.Erase user data when asked
    5.After installation just do a factory reset just in case
    6.Reboot
    Your device should boot into OOS 5.0.8.
    Normally it takes around 2-5 to boot up
    Then setup your device and you are good to go
    Just remember to download the full ROM for your device OnePlus 3T
  8. revonomics
    Eclair Feb 20, 2019
    revonomics , Feb 20, 2019 :
    yes I did reply to stable OS long back but still no Pie update. I heard late Jan of 2019 OPT3 users will get it, but still no update.
  9. ghostofcain
    Marshmallow Feb 27, 2019
    ghostofcain , Feb 27, 2019 :
    You heard wrong, there is no ETA on P.
  10. revonomics
    Eclair Feb 27, 2019
    revonomics , Feb 27, 2019 :
    which means op3t users will get android Phone or not?.
  11. 9900099
    Cupcake Feb 27, 2019
  12. ghostofcain
    You WILL get Pie but there is NO ETA.
  13. Paul0209
    Cupcake Mar 8, 2019
    Paul0209 , Mar 8, 2019 :
    Hello, i need that Beta version too, to revert from Oreo to Nougat on the OP3. Does anybody still has the file?
  14. elykia
    Cupcake Mar 12, 2019
  15. Deactivated User
    Mar 22, 2019
  16. Pantelist Triantafillidis
    Cupcake Apr 2, 2019
    girishp likes this.
  17. girishp
    Gingerbread Apr 3, 2019
  18. abhibnl
    Ice Cream Sandwich Apr 4, 2019
  19. abhibnl
  20. Pantelist Triantafillidis
    Cupcake Apr 9, 2019
