199
[GUIDE] How to go from Oreo to Stock Nougat
  1. abhibnl Ice Cream Sandwich Apr 9, 2019
    abhibnl, Apr 9, 2019 :
    These are special builds. you should flash them in stock recovery/TWRP, do a complete internal memory wipe and then flash the last stable nougat OOS.
  2. girishp Gingerbread Apr 10, 2019
    girishp, Apr 10, 2019 :
    I'm using OP3T, and just went from Open Beta to Stock. I used special build from the link provided by @abhibnl.
    abhibnl
    Links for special builds. I won't ask for any money or anything. Don't worry. I am not cheap like those idiots in last pages:
    OP3T: (Found on the Internet)
    https://downloadmirror.co/Waa/O2N_OBT_15811_OXYGEN_SIGN_wipe.zip
    OP3: (Found on the Internet)
    https://downloadmirror.co/Wa9/O2N_OBT_15801_OXYGEN_SIGN_wipe.zip
    The device is working fine, and it's far better (in terms of smoothness) than OB.
    I got two OTA (~1.5gb each) after the following this procedure. Please note that these 2 OTAs are in addition to 2 installation mentioned in the procedure. So, if you planning to go from OB to stock, keep this in mind and be ready for two OTA updates.
  3. abhibnl Ice Cream Sandwich Apr 10, 2019
    abhibnl, Apr 10, 2019 :
    Can you please post a SS of your about section inphone? I think the OTAs you downloaded upgraded you again to Oreo.
  4. girishp Gingerbread Apr 10, 2019
    Here it is:
  5. abhibnl Ice Cream Sandwich Apr 10, 2019
    As you can see, you are back to Oreo, 5.0.8. So, i am curious to know, were you trying to get back to Nougat or just wanted to switch to a stable OOS version from your current OB?
  6. girishp Gingerbread Apr 10, 2019
    I needed stable.
  7. abhibnl Ice Cream Sandwich Apr 10, 2019
    Then could have easily just flashed stock OOS 5.0.8 on top of your OB ROM. No need for the Nougat rollback. But if it worked out in the end, good enough!
  8. girishp Gingerbread Apr 10, 2019
    Why such information is not available in this forum? People keep bullying #cupcakes all the times. Why main post of this thread had not been updated with such details! It would have been really helpful.
  9. abhibnl Ice Cream Sandwich Apr 10, 2019
    Actually, it's your fault mainly. If you read again, this thread is a guide for people to go back to Nougat from Oreo.
  10. girishp Gingerbread Apr 10, 2019
    Really? Look at this..
    And if there is a thread, which talks about OB to stock Oreo, why it has not been pinned?
  11. girishp Gingerbread Apr 10, 2019
    @SoniaB, requesting you to please update (main post of) this thread with necessory details.
  12. L1554521330431 Cupcake Apr 15, 2019
  13. Pantelist Triantafillidis Cupcake Apr 23, 2019
  14. RogerOriginals Ice Cream Sandwich Apr 29, 2019
    RogerOriginals, Apr 29, 2019 :
    He probably meant "Stock Oreo to Stock Nougat"
  15. C1529039063626 Cupcake May 16, 2019
    C1529039063626, May 16, 2019 :
    download the stock room from a trusted site and flash through recovery like twrp if rooted or preform a local upgrade in settings
  16. Pantelist Triantafillidis Cupcake May 16, 2019
  17. Gulam_Ambia_Shaikh Cupcake May 24, 2019 at 1:53 PM
    Gulam_Ambia_Shaikh, May 24, 2019 at 1:53 PM :
    The One Plus 3 OBT download page isn't available. Any other source of download?
  18. C1529039063626 Cupcake May 24, 2019 at 1:56 PM
    C1529039063626, May 24, 2019 at 1:56 PM :
    stable update officially rolled out
    if you still want local upgrade then refer to xda
    it has bunch of local upgrades available
  19. C1529039063626 Cupcake May 24, 2019 at 1:57 PM
    C1529039063626, May 24, 2019 at 1:57 PM :
    for which version do you want the link?
