153
[GUIDE] How To Make A Clean Installation Update Or A Deep Clean Data Wipe To Your OnePlus Smartphone
  1. gaster
    Lollipop Moderator Dec 16, 2018
    gaster , Dec 16, 2018 :
    Hi friend. You better check YouTube with benchmarks and feedback about the best OS for the OPO currently. That's the best in my opinion.
  2. R_Dodge
    Cupcake Dec 16, 2018
    R_Dodge , Dec 16, 2018 :
    Thanks for the advice Gastor.
    What specifically am I looking for? Can I follow the first post you made about doing a clean install + full wipe of device?
    gaster likes this.
  3. wilsmits
    Jelly Bean Dec 17, 2018
  4. gaster
    Lollipop Moderator Feb 6, 2019
    gaster , Feb 6, 2019 :
    As much as we talk for the process that has already been tested in the devices and the versions of the OS I have mentioned, I guess that you can.
  5. G_Nairn_Comyn_Jvgm
    Cupcake Jun 11, 2019
    gaster likes this.
  6. H1550749123362
    Cupcake Sep 22, 2019
    H1550749123362 , Sep 22, 2019 :
    Hi thanks for the updating for more than 4 years. Here I have another question: does anyone know how to do a deep clean (not only clean cache or format the phone, but remove the system partition) before the updating without Root?
  7. gaster
    Lollipop Moderator Sep 22, 2019
    gaster , Sep 22, 2019 :
    Hi friend. As mucha as I know, there is not a way to do wipe the system partition without a root. The best you can do in this case is to flash the Fastboot commands from the scratch that they will wipe anyway the system partition and it will be like out of the box device again.
  8. H1550749123362
    Hi bro thanks for your reply, well, the situation is slightly changed. Since the Andoird 10 is released, I just want to do a deep clean before the installation. So when I update the system, will Android 10 will remove everything from the system partition?
    gaster likes this.
  9. gaster
    Lollipop Moderator Sep 23, 2019
    gaster , Sep 23, 2019 :
    If you will update form the Android 9 Pie by using the official OTA and official latest Android 9 Pie build, I don't think it will be wiped. It just replace the core OS files with the new of Android 10. But are you talking for OnePlus 7/7 Pro?
    V1540363683824 likes this.
  10. V1540363683824
    Eclair Mar 17, 2020
