51
[GUIDE] How to make optimal use of your One' screen size!
  1. Enyalius
    Jelly Bean Feb 20, 2015
    Enyalius , Feb 20, 2015 :
    You can make your One whatever you want it to be. I do believe that changing the value to 200 will make it difficult pressing some buttons on your screen. But you won't find out unless you try. Give it a shot and let us now :)
  2. Enyalius
    Good feedback, cheers!
    OneRNDPHLive likes this.
  3. Enyalius
    There is no sweet spot, it's user dependent. Everybody can have another sweet spot. Try it out.
    No downgrade. Movies stay equal resolution, regardless of value you set.
    It's not the dpi you're changing, it's a value. Your dpi is fixed to what the screen can handle at most (hardware). Lowering dpi value has, in my opinion, no impact on battery life. It stays the same.
    abechung likes this.
  4. Enyalius
    No, not at all. All works like a charm. You can download and install all apps like you would with standard dpi value.
    Change the spirit :), see what it has in store for you :D
    maitri karuna likes this.
  5. omkonda
    Cupcake Feb 20, 2015
    omkonda , Feb 20, 2015 :
    in cm12 nightly after editing build prop, settings force closes every time.
  6. Enyalius
    Sorry can't help you there. Have never used the nightlies
  7. omkonda
    finally no force closes at dpi value 420.
  8. Enyalius
    Jelly Bean Feb 21, 2015
  9. opo612
    Cupcake Feb 21, 2015
    opo612 , Feb 21, 2015 :
    Try on Tues or do what I did check Craigslist. I got one for $280. I've seen them for as low as $240.
    Bluewatersurf likes this.
  10. shantanu9264
    Donut Feb 21, 2015
    Enyalius likes this.
  11. Enyalius
  12. aquila
    Honeycomb Feb 21, 2015
    aquila , Feb 21, 2015 :
    Yeah, basically that. ;)
  13. madrosh
  14. Enyalius
  15. kkizz
    Donut Feb 22, 2015
    kkizz , Feb 22, 2015 :
    I'll give it a try. Thanks
  16. Enyalius
    Jelly Bean Feb 22, 2015
    Enyalius , Feb 22, 2015 :
    Let us know how it works out.
  17. kkizz
    Donut Feb 22, 2015
    Here's what I discovered:
    1. Font: Minimal Teal is ok. But I prefer Obsidian (available free on Google Playstore)
    2. Font size: Depending on your age I prefer to keep the size to 100%.
    3. Swiftkey: I like the colour of holo theme because I can see clearly the colour change of the shift key when I want to capitalise my text. Also I added Accented Characters & a Number row on my keyboard.
    4. DPI: I dare not tinker around with that. Sorry.
    5. Grid size: 4 x 5 is just fine for me as 7 x 6 is way too small for a guy's finger & makes the desktop appear too crowded
    6. I too recommend the use of the capacitive buttons as the onscreen navigation buttons can be cumbersome to use as they will disappear after a few seconds when you enable "expanded desktop" & will only reappear once you slide them up.
    7. Enabling Expanded desktop: Besides what I have pointed out above, as you already knew, enabling expanded desktop will also deactivate double tapping of the status bar to bring the phone to sleep function. However there's another option available. Under buttons enable the Quick
    Launch Shortcuts (only when onscreen nav is enabled). Slide your finger up from the bottom of the screen & 3 slots will appear where you can specify which function shortcuts you want to launch. You can place the sleep button here. I would also recommend to place the "screenshot" shortcut here too. These shortcuts will appear by sliding your finger from the bottom of the screen. Then touch any shortcut button that you desire.
    Forgive me for any shortcomings.
    ubizmo likes this.
  18. rpajak
    Eclair Feb 22, 2015
    rpajak , Feb 22, 2015 :
    will definitely try this when I get my OPO, just need a invite.. cough.. :)
  19. Enyalius
    Jelly Bean Feb 23, 2015
    Enyalius , Feb 23, 2015 :
    Thanks for your feedback! Definitely might be useful for some users who prefer slightly different settings.
    As for the Grid size - once you change DPI, changing grid size to 7x6 (or even 8x6, what I currently have running), is no problem at all :)
    kkizz likes this.
  20. Enyalius
    Try the no-invite Tuesday :D
