203
[GUIDE] How to Unroot your OnePlus 3 / 3T and go back completely to stock
  1. appumohan Cupcake Apr 27, 2017
    appumohan, Apr 27, 2017 :
    i am using render kernel LOS version. Do i need to install kernel for OOS or just flash the Rom ??
  2. Sun90 Lollipop Apr 27, 2017
    Sun90, Apr 27, 2017 :
    Try flashing the ROM and see.
    If all goes fine then ok.
  3. appumohan Cupcake Apr 27, 2017
    Locking the bootloader is compulsory ?? I mean last time i tried without locking the install failed half way. Cant install via twrp. Showing error
  4. Sun90 Lollipop Apr 27, 2017
    No, locking Bootloader is not compulsory.
    anmo_gupta_4 likes this.
  5. Samuele9 Cupcake Apr 28, 2017
    Samuele9, Apr 28, 2017 :
    When I go to do the adb update, the cmd say "cannot read 'ota.zip'"... Sorry for my bad English
  6. appumohan Cupcake Apr 28, 2017
    appumohan, Apr 28, 2017 :
    Me too had the same problem. Reinstall the USB drivers. If its not working maybe the zip file is corrupted. Download another copy.
  7. Samuele9 Cupcake Apr 28, 2017
    The drivers are ok, they work with all the input. I tried different zip but did't work
  8. Sun90 Lollipop Apr 28, 2017
    Sun90, Apr 28, 2017 :
    Is it windows 10 on your PC for now.
  9. appumohan Cupcake Apr 28, 2017
    i had the same problem. I used another computer then no 'cannot read' message. install fails at 47%
  10. G_Nancy_Porter_ffQG Cupcake Apr 30, 2017
  11. anmo_gupta_4 Donut May 1, 2017
    anmo_gupta_4, May 1, 2017 :
    Just tried the method. Works just fine and so easy! Thanks a lot for this simple guide. :)
    calvinistmac likes this.
  12. calvinistmac Jelly Bean May 1, 2017
    calvinistmac, May 1, 2017 :
    Glad this has been helping people out. I will be making a slight update soon(tm) to the guide to change up some wording and smooth out the process a little bit. Don't know exactly when that's going to happen, so just keep your eyes on the OP.
    Sun90 likes this.
  13. mitchoyotone Cupcake May 2, 2017
    mitchoyotone, May 2, 2017 :
    I've seen this been an issue in this thread, but I still cannot find a solution. I keep getting the "cannot read <filename>" while side loading. I've re-downloaded the file multiple times, into different locations, different pc's and same problem. I've uninstalled and re installed drivers. I've tried using large file aware, which I didn't think would make a difference in my case but what the hell, gave it a shot. A little desperate now, frustrated, lol.
    As for asking for help, I know there is only so much you can do without being at my desk, but has anyone thought of other suggestions/workarounds?
  14. elanglois KitKat May 2, 2017
    elanglois, May 2, 2017 :
    Congrats on getting this right and with exceptional detail. Very well done!
    calvinistmac and Sun90 like this.
  15. calvinistmac Jelly Bean May 2, 2017
    calvinistmac, May 2, 2017 :
    If you do a search through this thread you will find the answer. Please utilize the search function. It works pretty well.
    mitchoyotone likes this.
  16. suvrat29 Froyo May 3, 2017
    suvrat29, May 3, 2017 :
    There are many reasons for this one: drivers not installed, permissions, adb incorrectly installed, the zip might be corrupt, opening command prompt without admin rights or something wrong with your process.
  17. suvrat29 Froyo May 3, 2017
    How about you flash the stock recovery via fastboot (command: fastboot flash recovery <recovery name>.img) and then perform a full wipe including data, and then try sideloading? Works for me as a last resort.
    Note: You should have an unlocked bootloader.
    And the usb drivers installed which appear when you connect your phone.
  18. mitchoyotone Cupcake May 4, 2017
    mitchoyotone, May 4, 2017 :
    Thanks much! Found the solution. Didn't realize the search bar. Will definitely keep it in mind.
  19. mitchoyotone Cupcake May 4, 2017
    Figured it out. Full data wipe and reinstalled drivers again, seemed to do the trick. Thanks!
    suvrat29 likes this.
  20. suvrat29 Froyo May 4, 2017
    suvrat29, May 4, 2017 :
    Great!
