203
[GUIDE] How to Unroot your OnePlus 3 / 3T and go back completely to stock
  1. calvinistmac Jelly Bean May 4, 2017
    calvinistmac, May 4, 2017 :
    You are the first person to not flame me for asking you to utilize the search function! Kudos to you my friend. Glad everything worked out!
    Sun90 likes this.
  2. MattLyte Cupcake May 7, 2017
    MattLyte, May 7, 2017 :
    Trying to flash back to 4.1.3, the recovery installs fine but trying to flash the OTA zip from adb just instantly fails at connecting every time. All it says is "Installation failed." It won't let me unlock from the bootloader, and I can't flash anything in adb! This thing has unquestionably been the worst phone I've ever owned.
  3. JorgeManuelSilva91 Ice Cream Sandwich May 10, 2017
    JorgeManuelSilva91, May 10, 2017 :
    This post may be helpful:
    https://forums.oneplus.net/threads/...pletely-to-stock.456232/page-29#post-15836034
  4. F_Mathias_Brands_DLRK Cupcake May 17, 2017
    F_Mathias_Brands_DLRK, May 17, 2017 :
    i got one small problem i'm like at the step where ou need to install from adb but if i type adb sideload ota.zip it says cannot read ota.zip. what should i do?
  5. calvinistmac Jelly Bean May 18, 2017
    calvinistmac, May 18, 2017 :
    You need to read back in the thread a bit. The answer has been given.
    Sun90 likes this.
  6. m_a_n_i_s_h Honeycomb May 18, 2017
  7. calvinistmac Jelly Bean May 19, 2017
    calvinistmac, May 19, 2017 :
    The fact that you're asking me this question tells me that you didn't read the first post, at all. Please read the first post for your answer.
    Sun90 likes this.
  8. pal.sayan3 Donut May 20, 2017
  9. calvinistmac Jelly Bean May 20, 2017
    calvinistmac, May 20, 2017 :
    If you read the OP (original post) you would know the answer to this question. Since I'm feeling generous today I'll give you the answer. You will lose your data with this operation. Back up your data before attempting.
    Sun90 likes this.
  10. peroxide Cupcake May 21, 2017
    G_Nancy_Porter_ffQG likes this.
  11. peaky blinders Jelly Bean May 21, 2017
  12. isthatxavier Honeycomb May 22, 2017
    isthatxavier, May 22, 2017 :
    Does anybody have a link to fix drivers? My OnePlus 3t is being recognized but command prompt would just fail everytime. I did check adb devices and it's there but it won't push the zip.
    or any link with the steps or workaround for Windows 10
  13. G_Facundo_Rodrigo_Carbaj Cupcake May 22, 2017
  14. calvinistmac Jelly Bean May 22, 2017
    calvinistmac, May 22, 2017 :
    When the phone is hooked up open the Device Manager in Windows 10. You'll probably find a weird looking entry with some characters that says adb interface. You'll need to right click on that and update the driver manually to the correct adb drivers. This happens periodically. I don't have a step by step right now but that's basically what you need to do. If I don't respond you can also ping @JorgeManuelSilva91 for help as he checks this periodically to help me out.
    Sun90 likes this.
  15. iruvaramharsha Cupcake May 25, 2017
    iruvaramharsha, May 25, 2017 :
    Hello,
    I installed one plus 3t open beta updates on my rooted phone a few days ago. I want to completely unroot my phone so I checked the root checker it says "Sorry! Root access is not properly installed on this device". I checked the super su app it says "There is no SU binary installed and SuperSU cannot install it. This is a problem!
    I just want my phone to be normal as I want to use android pay. Do I need to still unroot it? My bootloader is still unlocked! Still in a kind of confusion if my device is rooted or unrooted. Please help me!
    Million thanks
    H.
  16. calvinistmac Jelly Bean May 29, 2017
    calvinistmac, May 29, 2017 :
    Sorry for the late response. Sounds like you have a botched SuperSU install. You are unrooted, but your bootloader is still unlocked. You can use the unrooting procedure to unroot it and put it back to the way you got it out of the box. Follow the instructions to the letter and don't skip anything.
    Sun90 likes this.
  17. shashwat mahar Donut May 29, 2017
    shashwat mahar, May 29, 2017 :
    no need to flash stock recovery after flashing stock rom unless you reboot to twrp
  18. shashwat mahar Donut May 29, 2017
    place ota in the same folder from where you are running cmd
  19. calvinistmac Jelly Bean May 29, 2017
    That's not entirely correct. The "cannot read ota.zip" error is usually a driver error. Please do some research before posting to avoid issues.
    Sun90 likes this.
  20. G_Robert_Partridge_AAQp Froyo May 29, 2017
