36
[Guide] Install CM13 Nightly on Oneplus One (Unlocked Bootloader Required)
  1. entrepreneur_ab
    Honeycomb Nov 24, 2015
    entrepreneur_ab , Nov 24, 2015 :
    Hello Everyone,
    Just like you, i was also waiting to get marshmallow in cyanogenmod. So, here it is as Nightly version of CM13 24/11/2015 (it's today)
    Instructions:
    Requirements:
    1. Oneplus One with Unlocked boot loader & Custom Recovery Installed e.g. twrp or twrp multirom etc. Or simply use wugfresh oneplus toolkit to unlock boot loader and install twrp.
    2. Download CyanogenMod Nightly CM13 & Gapps Package. ( You must have gapps for Android 6.0 with Platform - ARM)
    Steps:
    1. Download and transfer both zip files to your oneplus one.
    2. Reboot phone into Recovery Mode
    3. Select wipe >> Select advanced Wipe >> Select System+Data+Cache+Dalvik Cache >> Slide wipe button >> Go back & select Install >> Select cm-13.0-201XXXXX-NIGHTLY-bacon.zip >> Then select Add more zips >>Select GApps zip>> Swipe to confirm flash >> After completing >> Select wipe Cache/Dalvik >> Swipe to wipe >> DONE >> Reboot to System
    Below is video of this process, made by @hrishi21007
    Root CM13:
    [​IMG][/url][​IMG] [/IMG]
    Do not flash SuperSu.zip file Your phone wont boot after that. Insted go to Developer Menu & Select ROOT ACCESS. If you still want SuperSu then install it from play store.
    Known Bugs (Changelog to see improvement)
    1. No mobile data Resolved in
    cm-13.0-20151125-NIGHTLY-bacon.zip Use Cyandelta to update quickly.
    2. Video camera not working
    Solved
    3. Multi ROM CM13- Unable to boot CM13 (not tried as CM13 primary) Please try and report. Download Modified Multirom TWRP Link Courtesy @muerte
    Guide by @anidotnet
    The Normal CM 13.0 nightly builds won't install via MultiROM as a secondary ROM without a little tweak. The provided install script inside the ROM makes some checks that need to be disabled.
    To do this:
    • unzip the ROM zip file
    • edit the file /META-INF/com/google/android/updater-script
    • delete lines from "ui_print("Verifying the updated system image...");" to "show_progress(... , ... );" (including matching lines)
    • save the file
    • re-zip the ROM folder, making sure you don't add any additional subdirs (if you're using OSX Finder, select all the files in the ROM root folder, right click and choose "Create Archive", then rename the generated Archive.zip file)
    Now install the generated Archive.zip via MultiROM and enjoy CM13. (Still having lot's of bug though)
    4. Spot-on answers / Now on Tap feature not working. Solution:Flash Stock GApps & select Settings>>Buttons>>Home button>>Long press action>>Search assistant
    5. Wi-Fi battery drain. Temporary Solution: Disable wifi when not using or use Network Control in DU Battery Saver OR Battery Doctor Resolved
    6. Voice on any screen "Ok Google" Unable to detect microphone. Solved
    7. Other side person cannot hear your voice / hear poor voice in call. Solution Install Soundfix for oneplus. Root is required. OR wipe & clean install CM13 again will solve this problem,
    8. Radio active bug. Read here. Please give some solution. PM me to update here.
    Please report your experience in comments. I will update it here
    My experience with CM13 + Marshmallow: (in comparison with CM12+Lollipop)
    1. Improved battery life (thank you so much google)
    2. Battery profiles
    3. Smooth & fast touch.
    Other Interesting Stuffs:
    1. ColorOS / Oppo 50MP Camera App APK + Plugins Supports CM13:) Ref XDA
    2. Cyanogenmod C-Apps
    Download here (Dialer Crash problem after flashing C-Apps)
    More updates coming....
    [​IMG][/url] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG][/IMG]
  2. giaur500
    Jelly Bean Nov 24, 2015
  3. Formsma
    KitKat Nov 24, 2015
  4. B4kken
    Lollipop Nov 24, 2015
  5. shijopj2014
    Gingerbread Nov 24, 2015
    shijopj2014 , Nov 24, 2015 :
    Does this CM13 nightly have customizations...?? I mean in settings.. can add quick tiles...and many customizations
  6. Sherry8899
    Eclair Nov 24, 2015
  7. entrepreneur_ab
    sorry, i want to mean bootloader but in hurry i typed root.
  8. entrepreneur_ab
    yes, certainly M is better than L
    dadodd, caLinn and pgidia like this.
  9. entrepreneur_ab
    i think customization is same as cm12
    pgidia likes this.
  10. saptarshipaulchoudhury
    Eclair Nov 24, 2015
    sivas, entrepreneur_ab and pgidia like this.
  11. duskonbg
    Cupcake Nov 24, 2015
    duskonbg , Nov 24, 2015 :
    I have updated cm13 - 6.0 nightly from cm12.1 - 5.1.1 nightly and have google play services crush everi 3-10 second.Do I need just to install new gapps?
  12. theshinybeast
    Marshmallow Nov 24, 2015
    theshinybeast , Nov 24, 2015 :
    It's the first nightly, there are going to be bugs Don't expect everything to run smoothly.
  13. duskonbg
    entrepreneur_ab, Alainleon and pgidia like this.
  14. akvijendra
    akvijendra , Nov 24, 2015 :
    How does it install on multirom. Can I have cynogen 5.1 as the primary and then CM 13 on secondary?
  15. pgidia
  16. Jeffreyvdv3lde
    Jeffreyvdv3lde , Nov 24, 2015 :
    It can take up to a few weeks to fix the issues with the nightlies.
  17. NicholasYeo
    Donut Nov 24, 2015
    NicholasYeo , Nov 24, 2015 :
    Hello guys, I got a problem, I didn't notice the update for CM13 and I installed it as a normal update now my phone is stucked at optimizing apps and then it will loop. How do i go about this? I know how to enter teamwin recovery but I dont know what to do from there, I tried installing back previous versions and the same problem happens.
    entrepreneur_ab likes this.
  18. Param Kharoud
    Marshmallow Moderator Nov 24, 2015
    Param Kharoud , Nov 24, 2015 :
    Thread Title edited. Ping me if you need anything else.
    entrepreneur_ab and Formsma like this.
  19. mentaribiru
    Donut Nov 24, 2015
    mentaribiru , Nov 24, 2015 :
    if you're dirty flash from 12.1 you need to flash gapps for MM also.
  20. KalleKnipp
    KalleKnipp , Nov 24, 2015 :
    just flashed dirty CM13 coming from CM12.1, also new Gapps, works fine, BUT no mobile data connection..
