36
[Guide] Install CM13 Nightly on Oneplus One (Unlocked Bootloader Required)
  1. alessandromochi
    Cupcake Jan 22, 2016
    alessandromochi , Jan 22, 2016 :
    I will try thanks!!
  2. funzzz
    Donut Jan 25, 2016
    funzzz , Jan 25, 2016 :
    I'd get a USB OTG thing u know so you can flash from a drive. Copy the ROM file and the Gapps and flash them. Or use adb if you know how to.
  3. anmolrawat
    Cupcake Jan 28, 2016
    anmolrawat , Jan 28, 2016 :
    I have my bootloader unlocked and a rooted device, but I'm on stock cyanogen OS 12.1. Do I first need to flash the cm13 recovery or should I directly flash the ROM file?
  4. Tuski1998
    Eclair Feb 14, 2016
  5. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Feb 14, 2016
    mojoyoyo77 , Feb 14, 2016 :
    See post # 1
    Summarized:
    - Download Open gapps ARM Android 6.0
    - Download nightly
    Save downloads in internal memory
    - Reboot to recovery (TWRP 2.8.6.0 recommended)
    .......- Full Backup (recomended)
    .......- Wipes / Advanced wipes: "System", "Data", "Cache", "Dalvik Cache"
    .......- Install: Select the nightly rom & gapps and Flashing
    .......- Reboot
    To update
    - Download nightly
    Save download in internal memory
    .......- Wipes / Advanced wipes: "Cache", "Dalvik Cache"
    .......- Install: Select the nightly rom and Flashing
    .......- Reboot
  6. bahar_b
    Honeycomb Feb 15, 2016
    bahar_b , Feb 15, 2016 :
    Can twrp 3.0 be used as there are statement said twrp 2.8.6.0 only can flash cm13 properly.
    Thanks.
  7. killerbee13
    Jelly Bean Feb 15, 2016
    killerbee13 , Feb 15, 2016 :
    Don't use it to be sure. Lot of people have problems with twrp 3.0.0.0
    Twrp 2.8.6.0 or unofficial
    twrp materalized 2.8.7.0.5 works fine
  8. Tuski1998
    Eclair Feb 15, 2016
    Tuski1998 , Feb 15, 2016 :
    Its a secondary rom and reboot option does not function might be some bugs help me
  9. Tuski1998
    Eclair Feb 15, 2016
    Hey installing cm13 with twrp 3.0 comes a error same here it says "an error occured and multirom is shutdown"
  10. h0aX
    h0aX , Feb 15, 2016 :
    Use
    twrp materalized 2.8.7.0.5 worksfine
  11. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Feb 15, 2016
    mojoyoyo77 , Feb 15, 2016 :
    I do not use MultiROM, is recommended TWRP 2.8.6.0
  12. bahar_b
  13. parthiv009
    Jelly Bean Feb 16, 2016
  14. gwie
    gwie , Feb 16, 2016 :
    Titanium backup
  15. Konigche
    Cupcake Feb 16, 2016
    Konigche , Feb 16, 2016 :
    Is not working manual focus in the camera app. that option is locked, this is normal?
  16. akshay791
    Eclair Feb 16, 2016
    akshay791 , Feb 16, 2016 :
    Is it safe to switch from oxygen os 2.1.4 to cm 13 following the steps given in this thread?
  17. gwie
    Yes
    Yes, steps are fine if you take the requirements into account.
  18. akshay791
    Eclair Feb 16, 2016
    Can you please let me know what requirements i must consider? Also i flashed oxygen os through oneplus recovery so how do i install twrp on it? Im new at this so dont know much.
  19. gwie
    Requirements are in the first post. Look for a guide on twrp it's on the forums.
  20. Konigche
    Will this be enabled? o It is enabled in a future update? In an update he mentions that the focus manually fixed.
