36
[Guide] Install CM13 Nightly on Oneplus One (Unlocked Bootloader Required)
  1. atishkel
    Donut Nov 25, 2015
    atishkel , Nov 25, 2015 :
    Got 25-11. Works like a charm. Just reboot the phone after setting the correct APN. Woohoo :D :p
    entrepreneur_ab and amrutprabhu like this.
  2. kipperbusby
    Eclair Nov 25, 2015
    kipperbusby , Nov 25, 2015 :
    Google randomly stops at times for the new nightly.... now on tap cannot be activated because of this! Which pretty much almost ruins marshmallow if you cant use it.
    entrepreneur_ab likes this.
  3. kipperbusby
    Eclair Nov 25, 2015
    This usually happens when you go to enable now on tap or tamper with anything in the google app
  4. amrutprabhu
    Gingerbread Nov 25, 2015
    amrutprabhu , Nov 25, 2015 :
    yup... still data issue persists...
  5. kipperbusby
    Eclair Nov 25, 2015
    not for me... Im getting LTE now on ATT
  6. kaz04
    Eclair Nov 25, 2015
    kaz04 , Nov 25, 2015 :
    You add gapps right?
  7. amrutprabhu
    this solution worked for me... :) Now its working... happy ..:)
  8. kipperbusby
    Eclair Nov 25, 2015
  9. atishkel
    Donut Nov 25, 2015
    dude it worked. Just selected the correct APN in cellular network settings and REBOOT. it will work. I just did it. It worked
  10. kipperbusby
    Eclair Nov 25, 2015
    [​IMG]this is what happens when you try and enable now on tap. Anyone let me know if it works for you! Or if you find a fix!
  11. amrutprabhu
    Its not a full proof fix.. after changing the APN and rebooting , the data works, but then if i put off data and switch on wifi... then put off wifi, and switch on data again.. then the data doesnt work... It requires a reboot for it to work again...
    anyways... its a solution to no data at all....:)
  12. sivas
    sivas , Nov 25, 2015 :
    Can you pls provide the link to the Color OS app?
  13. sivas
    Now on tap works for me.
  14. JohanSmolders
    Eclair Nov 25, 2015
    JohanSmolders , Nov 25, 2015 :
    I have the same problem. Toggeling WiFi disables data and the only way to bring it back is a reboot.
    On tap working for me. I activated it in 24/11 nightly. I kept the home button pushed in on a random screen. Then it asked me if I would like to enable it.
    Other issue found. I'm using the plex app as a music player. When I try to play music it just doesn't start playing.
  15. hrusateesh
    Honeycomb Nov 25, 2015
    hrusateesh , Nov 25, 2015 :
    Two strange issues found. In system ui tuner, adding a broadcast title not bringing any keyboard. More over with that popup open, lock the screen and unlock it. You still see that popup.
  16. se7enlyn
    Ice Cream Sandwich Nov 25, 2015
    se7enlyn , Nov 25, 2015 :
    on your opo, set the language to english us, then go to google now and enable it.
  17. brucem
    Froyo Nov 25, 2015
    brucem , Nov 25, 2015 :
    My WiFi connection is going crazy - every few seconds it disconnects, then reconnects... nobody else got wifi problems?
  18. aaron.hossain75
    Lollipop Nov 25, 2015
    aaron.hossain75 , Nov 25, 2015 :
    Write in English!
  19. Utkarsh verma
    Froyo Nov 25, 2015
    Utkarsh verma , Nov 25, 2015 :
    Error exectuting update in binary some think like that ..... I know it coz of old firmware where to find new firmware .... Coz i want to flash cm 13 as secondary while cm11 as primary.... Any solns..??
  20. SunSpear
    SunSpear , Nov 25, 2015 :
    There are a few threads with links. Just search for Color OS camera apk. That should do it. Have fun!
