25
[GUIDE] Mega Unbrick Guide for A Hard Bricked OnePlus 6
  1. Titokhan
    Honeycomb May 27, 2018
    Titokhan , May 27, 2018 :
    Similar to the previous threads for OnePlus 2, OnePlus 3 (3T), OnePlus 5 (5T), here are the necessary packages to unbrick/revive a hard bricked OnePlus 6.
    Download: https://www.androidfilehost.com/?w=files&flid=271466
    With the device powered off, hold Volume Up button to force it to boot to Qualcomm download mode.
    For detailed procedures, please consult the linked threads above. There is no reason to repeat the same thing again.
    Make sure the path of the extracted files doesn't contain any non-English character. The tool isn't unicode aware.
    Source:
  2. Titokhan
    MarkoBatrac, Nezumi_ and idkwhoiam322 like this.
  3. Nezumi_
    KitKat May 27, 2018
    otto2, idkwhoiam322 and Titokhan like this.
  4. idkwhoiam322
    Nougat May 27, 2018
  5. Daan_Eekhofアニメ
    Jelly Bean May 27, 2018
    idkwhoiam322 likes this.
  6. jcespi2005
    Ice Cream Sandwich May 27, 2018
    jcespi2005 , May 27, 2018 :
    Someone tested?
    Seems there are some files mising...
    Help needed, I have a friend with a hard brick...
  7. jcespi2005
    Ice Cream Sandwich May 28, 2018
  8. Titokhan
    Honeycomb May 28, 2018
    RoonShady likes this.
  9. jcespi2005
    jcespi2005 , May 28, 2018 :
    I found the issue, you was totally right, the ZIP downloaded from androidfilehost.com has chinesse characters in the name, so i renamed the unziped folder to some other non chinesse name, and now it's working fine ;)
    Many thanks for the tip.
    Titokhan likes this.
  10. Titokhan
  11. Titokhan
    Honeycomb Jun 5, 2018
  12. Bastiaanoskam
    Eclair Jun 5, 2018
    Bastiaanoskam , Jun 5, 2018 :
    MsmDownloadToolV4.0InternationalVersionOxygenOS5.1.5.rar
    After using it, the phone will be restored to Oxygen OS 5.1.5. It can be possible to upgrade to latest Oxygen OS by using full signed zip from this thread.​
    if you restore to 5.15, what are you going to upgrade to
    "it can be possible to upgrade to latest..."
    5.15 is the latest
  13. nerlim
    Cupcake Jun 19, 2018
    nerlim , Jun 19, 2018 :
    Thank you.
    I do not understand a thing, because after the restore with the tool, I can not update via ota as I did with the previous models?
  14. Santpir
    Cupcake Jun 23, 2018
    Santpir , Jun 23, 2018 :
    Ok, I also tried this procedure but nothing, the toolkit stops almost at the end of the "downloading System.img to system_a".
    I knew someone took up to 15 minutes, I left him logged in downloading all night. Anything!
  15. Bastiaanoskam
    Eclair Jun 23, 2018
    Bastiaanoskam , Jun 23, 2018 :
    try again..
    reinstall drivers power off, etc..
    OPEN TOOL AS ADMINISTRATOR!
  16. Leafguy_16
    Donut Jun 24, 2018
  17. Titokhan
    Honeycomb Jun 24, 2018
  18. Santpir
    Cupcake Jun 25, 2018
    Santpir , Jun 25, 2018 :
    thanks, solved!! :)
  19. ArmenianHacker
    Eclair Jul 11, 2018
    ArmenianHacker , Jul 11, 2018 :
    This is after of press "Start" in Upgrade mode. What have I do? (Solved)
  20. Gk Harsha
    Cupcake Jul 23, 2018
    Gk Harsha , Jul 23, 2018 :
    Do you need to enable OEM Unlocking for this method to work? I haven't enabled it and my phone randomly got bricked. Like it shut down on its own all of a sudden.
