3
[GUIDE] My battery settings for OnePlus 2
  1. aneesimran
    Honeycomb Oct 4, 2015
    aneesimran , Oct 4, 2015 :
    We all know Snapdragon 810 is s***, heats up quicker and worst thing is it's not battery effiecent, it kills the battery on my phone (see other SD810 phones and they also have mediocre battery life) as where as Sd808 on the other hand is slightly better and I'm not sure if it's because of the powerful adreno chip or 4 big cores.
    So I have been getting annoyed with battery so I have finally improved battery significantly and so far haven't noticed any difference in performance.
    So here's what I done:
    1. Flashed ak/ boeffla kernel
    2. Downloaded kernel auditor from play store
    3. Used kernel auditor to disable 2 big cores
    4. And downclocked the GPU to 500mhz from 600mhz
    Suprisingly, the phone is much cooler, and there hasn't been a hit in performance such as Web browsing and opening apps, scrolling etc.
    P. S. I don't do heavy graphical gaming so this settings are probably good for me and a lot of others.
    Hope you have found this useful. Thanks
    Edit: prior to this I was getting 3 hour SOT as where as now I am achieving around 5 hours.
    Benchmark wise I'm getting 56000 on antutu which is around 5000 points lower but still higher then all the SD808 competitors such as Moto X style and G4
    Ashwith, pgidia and Gaurav Rohilla like this.
  2. vipul rathod1985
    Cupcake Oct 4, 2015
    aneesimran likes this.
  3. RedNile
    Gingerbread Oct 4, 2015
    RedNile , Oct 4, 2015 :
    Why would you buy a high-end device with a sd 810 and disable 2 of its cores? :eek:
    AkshayMurali1209 and Buzzrr like this.
  4. austinmehmet
    Froyo Oct 4, 2015
    austinmehmet , Oct 4, 2015 :
    Because battery life
    aneesimran and Gaurav Rohilla like this.
  5. pgidia
    Lollipop Oct 4, 2015
    pgidia , Oct 4, 2015 :
    If you are not using HD games then your battery life would be normal
  6. Gaurav Rohilla
    Gaurav Rohilla , Oct 4, 2015 :
    he can again enable those cores friend:)
    Ashwith, pgidia and aneesimran like this.
  7. aneesimran
    Firstly I didn't notice any performance difference, but still it's better then Sd808 as it's got faster and newer gen RAM and still a better GPU
    Ashwith and Gaurav Rohilla like this.
  8. parthcool
    parthcool , Oct 4, 2015 :
    What the whole use of buying the phone if you are switching off 2 of its cores? Such a shame :p
  9. keessonnema
    KitKat Oct 4, 2015
  10. Scherpenseel
    KitKat Oct 4, 2015
    Buzzrr likes this.
  11. Ashwith
    Jelly Bean Oct 4, 2015
    aneesimran and pgidia like this.
  12. b2gbang
    Froyo Oct 4, 2015
    b2gbang , Oct 4, 2015 :
    Is there any tutorial to flash custom kernel with twrp? Is it like flash custom ROM?
  13. aneesimran
  14. be300test
    Cupcake Oct 4, 2015
  15. aneesimran
    What I was planning is once ak kernel gets overclock feature I can overclock to the default frequency of 2.0ghz and still keep dual core and undervolt, hopefully that should keep battery good and gain in performance
  16. TZepek
    Eclair Oct 4, 2015
  17. xxBrun0xx
    xxBrun0xx , Oct 4, 2015 :
    I was under the impression we couldn't underclock the GPU yet? That's really what's going to save you battery, disabling cores will be pretty minimal.
  18. mansahr
    Froyo Oct 4, 2015
    mansahr , Oct 4, 2015 :
    Did the underclocking affect anything else, videos stuttering or something similar?
  19. aneesimran
    Absolutely nothing so far, performance and smoothness has been exactly the same, that's what really surprised me
    mansahr likes this.
  20. aneesimran
    You might be right because everytime I go on kernel auditor it keeps resetting my gpu clock freq to normal
    xxBrun0xx likes this.
