77
Guide
Guide on how to set notification slider to all/vib/none
  1. Greenforty Honeycomb Sep 20, 2015
    Greenforty, Sep 20, 2015 :
    This guide is outdated check out the new guide:
    https://forums.oneplus.net/threads/...-all-none-no-root-or-xposed-framework.689721/
    This guide will show you how to make your notification slider on your Oneplus 2 put your phone in All notifications - Vibration - or None.
    For this guide you'll need an app called tasker
    https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm
    step 1:
    First you want to make sure everything is checked in your priority interruptions setting so it looks like this
    step 2:
    After that you can open tasker and you should create a new profile (name it what you want) -> state -> variable
    and make sure it looks like this
    step 3:
    Then you should create a new task (name it what you want) -> audio -> ringer volume
    step 4:
    repeat step 2 but make sure it looks like this
    Step 5:
    now repeat step 3 but make sure it looks like this
    *fix for no notifications mode*
    retep 2 but make sure it looks like this
    after adding this you can assign the event created from either step 3 or step 5
    fix for no active profiles (thanks to @@Beedog1221 )
    Go to sounds and notifications and scroll go the bottom where it says notification access and enable tasker and it will work
    Here is a video showing how to do it
    Save everything and back out of the app and everything should work. If you have any questions be sure to ask them in the comments.
  2. pa5t1s Marshmallow Sep 20, 2015
    gaster, Greenforty and Bartnl like this.
  3. Bartnl Lollipop Sep 20, 2015
    Greenforty and pa5t1s like this.
  4. Tokolozi Marshmallow Sep 20, 2015
  5. vijayvk84 Honeycomb Sep 20, 2015
    vijayvk84, Sep 20, 2015 :
    Thanks for sharing, was looking for something like this from the time I got my OPT.
    Greenforty likes this.
  6. Gaurav Rohilla Lollipop Sep 20, 2015
  7. Samin007 Honeycomb Sep 20, 2015
  8. Greenforty Honeycomb Sep 20, 2015
    That's weird, since it shouldn't change those settings
  9. Greenforty Honeycomb Sep 20, 2015
    Fixed, I will add that right now
  10. Gopalsamant Gingerbread Sep 20, 2015
  11. hadogumu Ice Cream Sandwich Sep 20, 2015
  12. Martino1plus Ice Cream Sandwich Sep 20, 2015
  13. Samin007 Honeycomb Sep 21, 2015
    Samin007, Sep 21, 2015 :
    But cannot see the image..!!!!
  14. slytidar Donut Sep 21, 2015
    slytidar, Sep 21, 2015 :
    did everything exactly but phone dosent change to vibrate but when i push it to most top alarm only works with no sound and all but i think it is normal.
    Thous tasker in the notification says no profiles selected .. why ?
  15. de5imunda Donut Sep 21, 2015
    de5imunda, Sep 21, 2015 :
    Done exact same thing but phone is still ringing in priority mode. :/ I really need this fix Mann!!
    Beedog1221 likes this.
  16. atiq.qasim.12 Honeycomb Sep 21, 2015
    atiq.qasim.12, Sep 21, 2015 :
    Awesome guide.
    This guide just opened up so much possibilities for alert slider.
    Now i can set any action to take place when alert slider changes.
  17. silvorr Cupcake Sep 21, 2015
    silvorr, Sep 21, 2015 :
    hi i cant see the last screenshot which is namend *fix* maybe u can reupload?
    thanks for this awesome guide !
  18. ronton90 Donut Sep 21, 2015
    ronton90, Sep 21, 2015 :
    Thanks a lot for this awesome guide.. But as mentioned earlier the last image isn't viewable! Please upload it again. A video showing how to do this would be really helpful. I'm not really sure if I'm following everything correctly as I'm pretty new to Tasker. I've rooted my phones and played with a lot of custom roms but never entered the world of Tasker!
    Awaiting that image or a video!
  19. Greenforty Honeycomb Sep 21, 2015
    silvorr and ronton90 like this.
  20. Mel_Shenron Gingerbread Sep 21, 2015
    alfieeee likes this.
