3
Guide on Installing Xposed on OP3 Oxygen OS
  1. geekyprem
    Donut Jul 16, 2016
    geekyprem , Jul 16, 2016 :
    Hi,
    In this thread i am guiding you how to successfully install Xposed on Oxygen OS so Lets get started.
    Please Note that, Your phone must be rooted and Custom recovery Should be installed ( TWRP ).
    Important Files.
    1. Latest ARM 64 Xposed ZIP File - From Here
    2. Latest Xposed Installer APK - From Here
    How to Install
    • Go to Recovery
    • Flash Xposed ZIP File
    • Reboot the Phone
    • Now Install Xposed Installer APK
    • Now Open Xposed APP and Boom You are ready to go.
    Personally Tested Modules
    • Gravity Box (MM)
    • Youtube Background Play
    • Amplif
    • Greenify
    Thanks
  2. stephenboyo
    KitKat Jul 16, 2016
    stephenboyo , Jul 16, 2016 :
    Thanks. How will Xposed benefit the OP3?
  3. deathstocker
    Gingerbread Jul 16, 2016
    deathstocker , Jul 16, 2016 :
    It can inject modules in the system and give you several functions and features like those of CM even on a stock ROM. More customizability and awesomeness.
  4. #DoN_maX
    Froyo Jul 16, 2016
  5. stephenboyo
    KitKat Jul 16, 2016
    OK that's great! Will it prevent dash charging from working?
    PuppyPR likes this.
  6. pablofg1978
    Nougat Head Moderator Jul 16, 2016
  7. deathstocker
    I don't think so. Unless you mess up that program which checks if the charger connected is a dash one or not, I guess? That being done with Xposed unintentionally is very improbable.
  8. Vibhor_1911
    Eclair Jul 17, 2016
    Vibhor_1911 , Jul 17, 2016 :
    How to install Gravity box module?
    EDIT:- Nevermind... Got the MM installer in downloads section.
  9. UsmanRaza
    Cupcake Jul 20, 2016
  10. notcyf
    Honeycomb Jul 20, 2016
    notcyf , Jul 20, 2016 :
    Somehow Xposed severely slows down my OnePlus 3 on OOS official, even without modules.
  11. geekyprem
    Donut Jul 21, 2016
    geekyprem , Jul 21, 2016 :
    Did You click on Soft reboot or Reboot from Xposed Framework?
  12. deathstocker
    Gingerbread Jul 22, 2016
    deathstocker , Jul 22, 2016 :
    What about the Xposed Systemless versions? Will they work on OP3 correctly? I rather not change the system partition as I'd like to receive OTAs in the future.
  13. gupta_aahan
    Cupcake Jul 28, 2016
    gupta_aahan , Jul 28, 2016 :
    The Xposed framework slows down my OP3 too, but only when i add and enable modules. It all becomes really stuttery
  14. emerudesoo
    Donut Aug 7, 2016
  15. Raven6681
    Froyo Aug 12, 2016
  16. joaochastre
    Gingerbread Aug 17, 2016
    joaochastre , Aug 17, 2016 :
    Well I am... Xposed framework is not "sticking" installation on twrp goes smoothly, it even creates a file name xposed.prop under system. But when I reboot into system that file is no longer there and I checked for permissions on the system folder and they are all active, any ideas on how to fix this?
  17. cohaolain
    Honeycomb Aug 18, 2016
    cohaolain , Aug 18, 2016 :
    Modules I'm using that you might like:
    Youtube Background Playback
    Zoom for Instagram
    Custom Battery Meter
  18. Raven6681
    Froyo Aug 18, 2016
    Raven6681 , Aug 18, 2016 :
    if you are in 3.2.4, I had the same problem...
    wipe cache /dalvik/ data
    Reinstall 3.2.2
    Wipe cache / dalvik
    install OOS 3.2.4 full Rom
    Wipe cache/ dalvik
    Install SuperSU
    Wipe cache / dalvik
    Install XPosed v86 sdk23 arm64
    Wipe cache / dalvik
    Reboot
    kalashenicof likes this.
  19. boydivalor
    Honeycomb Aug 30, 2016
  20. clarenceethan
    Cupcake Sep 10, 2016
