94
OP3T [GUIDE] OnePlus 3/3T Unbrick
Seems like there are some problems with MSMDownloadTool in Windows 8.1, do you have any?
Poll closed Jun 14, 2017.
  1. Yes(please describe the problem in comments)
    1 vote(s)
    50.0%
  2. No
    1 vote(s)
    50.0%
  1. ginolla
    Cupcake Jun 13, 2018
    ginolla , Jun 13, 2018 :
    hello.... today i just tried to reboot my phone, it turns it off like always and never turn on again, I followed every single step in this guide, finish it without a error and still nothing.... any suggestion??
    here is result:
    dynamic_nvbk.bin: OK
    emmc_appsboot.mbn: OK
    gpt_backup0.bin: OK
    gpt_main0.bin: OK
    userdata.img: OK
    rawprogram0.xml: OK
    NON-HLOS.bin: OK
    rpm.mbn: OK
    static_nvbk.bin: OK
    tz.mbn: OK
    boot.img: OK
    cache.img: OK
    persist.img: OK
    recovery.img: OK
    system.img: OK
  2. Prahallad
    Froyo Jul 31, 2018
  3. Cervantes
    Lollipop Moderator Jul 31, 2018
    Cervantes , Jul 31, 2018 :
    The files that are sent to you for a technician to reinstall the operating system are only to download
  4. Prahallad
    Froyo Jul 31, 2018
    Prahallad , Jul 31, 2018 :
    Do you know password or able to crack above rar file
  5. Cervantes
    I do not know nor do I have the password
    What problem do you have?
  6. Prahallad
    Froyo Jul 31, 2018
    By above unbrick tool one will able to change beta to stable 5.0.4 in one step... No need twrp.
  7. Cervantes
    You have to do a clean installation
  8. martinklaus
    Gingerbread Jul 31, 2018
    martinklaus , Jul 31, 2018 :
    it's better to use the Normal zip form OnePlus website. I prefer to do this steps really if the phone is dead. The risk is to high that something goes wrong and you break you phone.
  9. Karan.jangra.54
    Donut Jul 31, 2018
  10. martinklaus
    Karan.jangra.54
    what is this unbricking is all about?​
    I had it on the first day I bought my phone. It's useful if you can't access os, recovery or Fastboot. Than you phone do nothing and you can only enable the flash mode. In older days was this way the default, but know the phones have enough intelligent layer that's not needed anymore.
    sprungy likes this.
  11. Karan.jangra.54
    Donut Jul 31, 2018
    Karan.jangra.54 , Jul 31, 2018 :
    oh okay
  12. Prahallad
    Froyo Jul 31, 2018
  13. finny007
    Cupcake Aug 24, 2018
    finny007 , Aug 24, 2018 :
    my phone comes up as Qualcomm HS-USB QDLoader 9008 (COM3) before I install the driver and then when I tried to run the unbrick tool it says Firehose GetUfsInfo failed and it says no device after it fails. a yellow light turns on my phone's notification light wont go away unless I press the power button
  14. sprungy
    Cupcake Aug 25, 2018
    sprungy , Aug 25, 2018 :
    finny007, I had to run the tool multiple times before it finally worked. don't give up!
  15. prestonrodz
    Gingerbread Oct 6, 2018
  16. martinklaus
    martinklaus , Oct 6, 2018 :
    yes
    prestonrodz likes this.
  17. The_Rock90
    Jelly Bean Oct 6, 2018
  18. Refuel
    Cupcake Oct 6, 2018
    Refuel , Oct 6, 2018 :
    Have bricked OnePlus 3T trying to follow this however device in not recognized by Windows tried on windows 10 and windows 8
  19. The_Rock90
    The_Rock90 , Oct 6, 2018 :
    long press power button on charging... try till it boots up. there's no other way... i got it luckily turned on like this. was not able to access recovery mode as well... tension aa gaya
  20. Refuel
    Cupcake Oct 6, 2018
    I've tried the long press a few times but it doesn't seem to do anything, guess I just have to keep trying thank you for the help
