90
[GUIDE] OnePlus 3/3T Unbrick
Seems like there are some problems with MSMDownloadTool in Windows 8.1, do you have any?
Poll closed Jun 14, 2017.
  1. Yes(please describe the problem in comments)
    1 vote(s)
    50.0%
  2. No
    1 vote(s)
    50.0%
  1. tontonfraguer Ice Cream Sandwich Oct 29, 2018
    tontonfraguer, Oct 29, 2018 :
    Hi guys, i got the same problem here.
    The phone (OP3) has shut down and is not responding to any command (Power ; Vol- + Power ; Vol+ + Power)
    No LED when connecting it to the charger.
    I managed to get it detected by Windows 10 by pressing Vol+ + Power and use the tool linked in this topic.
    All goes fine but the phone still stay silent and won't be back to life again.
    I need huge help.
  2. runingfrag Cupcake Nov 5, 2018
    runingfrag, Nov 5, 2018 :
    yep i'm having simillar issue contacted support replied with some "factory reset/clear cache " bulshit that prob everyone tries at first. and still no further response ... i sometimes can boot my device so i can downgrade to older version of android but well there is no old versions left in download sector :/
  3. The_Rock90 Jelly Bean Nov 6, 2018
    The_Rock90, Nov 6, 2018 :
    This has happened to me 5 times. it is because of water damage. keep pressing the power button till eternity
    it will power up... for sure ..
    but will take time
  4. Gepstra Eclair Nov 7, 2018
    Gepstra, Nov 7, 2018 :
    My god was this useful. Problems started when I relocked my bootloader.
    Then I got the Sahara Communication error constantly.
    Held the volume up button for 60 seconds and connected the phone to my PC. It seems that THEN you have to do Volume up + Power to get it to download the files!
  5. tontonfraguer Ice Cream Sandwich Nov 9, 2018
    tontonfraguer, Nov 9, 2018 :
    My phone never get water dommage and i can't try your trick anymore. I broke it in two part and throw it in trash.
    I bought a pocophone instead cause 6T is too expensive and this problem won't make me buy a new oneplus.
    Thanks for your post ;)
  6. The_Rock90 Jelly Bean Nov 9, 2018
    The_Rock90, Nov 9, 2018 :
    lol... I never said to press the phone in half. only press the power button[e]1f602[/e][e]1f602[/e][e]1f602[/e]
  7. M1544524048243 Cupcake Dec 11, 2018
    M1544524048243, Dec 11, 2018 :
    DAY GOOD AT ME Oneplus 3T. HAS TRIED ON THIS MANUAL TO RESTORE BUT THE PROBLEM IN THAT IT DOES NOT DOWNLOAD THE DESKTOP IS DISABLED BUT THE INDICATOR OF THE CHARGE SHOWS IN THE RECORDER ENTRIES. WHAT ELSE CAN BE DONE WHAT WOULD ITS RESTORE IT? AND HOW CAN I UNLOCK THE DOWNLOADER WITHOUT AN ENTRANCE TO THE SYSTEM SO I CAN'T TURN ON USK DECELERATION. PROMOTE SOLUTIONS
  8. Cervantes Lollipop Moderator Dec 11, 2018
  9. The_Rock90 Jelly Bean Dec 11, 2018
  10. M1544524048243 Cupcake Dec 12, 2018
    M1544524048243, Dec 12, 2018 :
    The problem is that the phone has stopped turning on. I tried to restore according to this instruction, the phone began to show that it is charging is included in the recovery menu but does not load the doc. the download goes then goes into reboot as if something is missing. what else can you do? And how can I unlock the bootloader if I can not log in?
  11. The_Rock90 Jelly Bean Dec 12, 2018
    The_Rock90, Dec 12, 2018 :
    you can go in recovery then you are ultra safe. are you able to go in recovery?
  12. M1544524048243 Cupcake Dec 12, 2018
    Yes, I can go into the recovery, I do a reset to the factory settings and the same thing does not load until the end
  13. M1544524048243 Cupcake Dec 12, 2018
    Can I unlock the bootloader without logging in?
  14. M1544524048243 Cupcake Dec 12, 2018
    Here is a photo where it enters the menu and the photo starts downloading and then it reboots and so constantly
  15. bart877ie Honeycomb Dec 13, 2018
    bart877ie, Dec 13, 2018 :
    I would just download latest oxygen file from oneplus website, connect phone to pc, paste to internal memory, and install from internal memory. I had similar problem,
  16. M1544524048243 Cupcake Dec 14, 2018
    M1544524048243, Dec 14, 2018 :
    How to get into the internal memory if I can not log in ???
  17. The_Rock90 Jelly Bean Dec 19, 2018
    The_Rock90, Dec 19, 2018 :
    you don't have a proper software installed. you'll have to install the software via adb side load
  18. M1544524048243 Cupcake Dec 21, 2018
    M1544524048243, Dec 21, 2018 :
    I can not unfortunately install via ADB because the bootloader is locked and it does not allow installing the software
  19. M1544524048243 Cupcake Dec 21, 2018
    Tell me how to enable USB debugging via ADB to unlock the bootloader
  20. syamkg12345 Honeycomb Dec 30, 2018
    syamkg12345, Dec 30, 2018 :
    Very useful thread... I did a similar one in my op5t...when my phone got bricked after updating to Android Pie..open beta.
