181
[GUIDE] OnePlus 3: How to Unlock Bootloader, Flash TWRP, Root, Nandroid & EFS Backup and More !
  1. Funk Wizard
    Lollipop Moderator Jun 18, 2016
    Funk Wizard , Jun 18, 2016 :
    Just leave it for now...
    #81
  2. Funk Wizard
    Reboot to recovery:
    TWRP > Wipe > FORMAT DATA . . "yes" to confirm
    Reboot to bootloader and type . .
    Code:
    fastboot format userdata
    Done
    #82
  3. G@urav
    Donut Jun 18, 2016
    G@urav , Jun 18, 2016 :
    what is this ? we have to do this apart from op thread ?
    #83
  4. injo1971
    Froyo Jun 18, 2016
    injo1971 , Jun 18, 2016 :
    Hey folks,
    I've unlocked and rooted, got SuperSu installed and all is fine. Thanks for the instructions!
    However, when I reboot it comes up with that 5 second delay counter. Can I change this behavior so I don't see that screen?
    Thanks!
    #84
  5. Naman Bhalla
    Recognized developer Recognized Developer Jun 18, 2016
    Naman Bhalla , Jun 18, 2016 :
    Wait until someone modifies the boot.img
    #85
  6. Fizzyb
    Froyo Jun 18, 2016
    Fizzyb , Jun 18, 2016 :
    Hi - After enabling the developer options and turning on the debugging oem and advanced reboot options , and also after installing ADB from your link, I am having issues with the drivers.
    I connect the OP3 to my PC and the new device wizard starts and tries to install drivers, first it looks at windows update for the drivers then in preconfigured folders then fails :( Any advice?
    i did install the ADB from the desktop and with 'run as admin'
    Where does the ADB.exe save the drivers to in windows so i can try to manually point to them
    #86
  7. Razer
    Froyo Jun 18, 2016
    #87
  8. Funk Wizard
    Optional if you want to decrypt the device
    #88
  9. danaughtyazn
    Cupcake Jun 18, 2016
    danaughtyazn , Jun 18, 2016 :
    Thanks MOD for the root guide.
    Every time I reboot my phone, my computer pops up with the "your device has been unlocked and can't be trusted" message and reverts back to the home screen. Is there a way to get rid of it?
    #89
  10. Naman Bhalla
    Not yet.
    #90
  11. someone12
    Donut Jun 18, 2016
    #91
  12. lkosova
    Ice Cream Sandwich Jun 18, 2016
    lkosova , Jun 18, 2016 :
    I just made another thread asking for a Rom for dummies guide for OP3 .....ha...much appreciated. Just going to read for now to learn.
    Thx.
    #92
  13. G@urav
    Donut Jun 18, 2016
    By default encryption is on? What is the best to go in future
    #93
  14. Fizzyb
    Froyo Jun 18, 2016
    #94
  15. danaughtyazn
    #95
  16. solidleon
    solidleon , Jun 18, 2016 :
    Is what loses maj stock if we apply this procedure?
    When it is the warranty?
    Thank you
    #96
  17. Revolised
    Gingerbread Jun 18, 2016
    Revolised , Jun 18, 2016 :
    I have the same behavior, so hopefully it is common.
    #97
  18. deveshr
    deveshr , Jun 18, 2016 :
    Hi I need help......the OxygenOS 3.1.2 update is available on my OP3. Should I update first and then root? Will it work? Please help!!
    #98
  19. Naman Bhalla
    Yes. It will work.
    #99
  20. Funk Wizard
