187
[GUIDE] OnePlus 3: How to Unlock Bootloader, Flash TWRP, Root, Nandroid & EFS Backup and More !
  1. chiliNknives
    Cupcake Aug 17, 2017
    chiliNknives , Aug 17, 2017 :
    Repost since this got moved to the Unrooting thread. I'm not trying to unroot the phone, but to root it and get stuck after installing SuperSU.
    Hello there,
    I'm on Oxygen OS 4.1.6(already had to reflash the OS for being stupid), TWRP 3.0.3-x and have the UPDATE-SuperSu-v2.79-20161211114519.zip in my download directory, shortly said I'm on the newest OS version with all the downloads as described in the OP. As noticeable I was able to install TWRP without a problem, backups and everything are working fine. My problem is whenever I try to install superSu(yes I checked the download if it's corrupt or anything) I just get stuck in the boot animation with the 2 dots stopping to move usually after the first reboot after the flash and my phone going black(apparently without turning off since I have to keep the power button pressed for longer to turn it off then on again). Before the new flash of the OS I had the same problem, but it also always told me while installing super su that /system couldn't be mounted. This problem doesn't seem to persist though. Is there any way to resolve this issue?
    Thanks a lot in advance for helping out :)
    P.S: It also always tells me at every boot that the dm-verity is not started in enforcing mode and may not work properly, does this maybe have something to do with it?
  2. nagarajsherigar
    Cupcake Aug 28, 2017
  3. SatriaPr
    Ice Cream Sandwich Sep 8, 2017
    SatriaPr , Sep 8, 2017 :
    @Funk Wizard can this thread be made sticky?
    I oftenly loose it and the search function doesn't help.
    And I guess new members won't bother using the search function, so I think it's just ideal to put it sticky.
    Now I'm using the watch thread tho.
    Thx
    Edit : I have just noticed that it's bookmarked in first post in one of the pinned thread, so I think it's good enough.
  4. julianfung94
    Cupcake Sep 10, 2017
    julianfung94 , Sep 10, 2017 :
    Hello,
    I followed your post step by step on how to root my OP3. Thank you for the awesome post and it was helpful.
    However, when I moved to step #4, I installed the zip folder on the TWRP recovery mode. Exactly according to your steps and screenshots. However, when it finished flashing SU and I pressed reboot, it showed the oneplus screen with black and white logo, and then the rotating animation with 2 white dots rotating around 1 red dot, and it just freezes after about 10 seconds, and then turns black and shuts off. What went wrong and what should I do?
    I have done a Nandroid backup through TWRP before flashing SU. I can still go into recovery right now and probably restore stock rom, but I am afraid to do anything before a second opinion.
    Any help would be much appreciated, thank you very much!
  5. RealUD7
    Gingerbread Oct 16, 2017
    RealUD7 , Oct 16, 2017 :
    First of all Thanks @Funk Wizard and @Naman Bhalla for this guide. I looked through the guide and have questions on each step since I haven't dealt with an encrypted device before (I'm currently on OB 24).
    1) At which step of this process, the built-in encryption is removed or do I have to remove it at any step?
    2) Won't the official TWRP work in the entire process?
    3) In the Step 1, you have mentioned that unlocking the device will wipe (all the data) off the device. But, in the Step 3, you have mentioned that there should be no screen security when making Nandroid backups. If unlocking wipes off the device how will the device have any screen security or is this instruction only for future Nandroid backups?
    4) Do I need to remove encryption before flashing a custom ROM in Step 4 if it hasn't already been removed during unlocking bootloader or flashing TWRP? Or will I be able to flash custom ROM over encrypted OOS?
    5) In Step 5 and 7, you have covered EFS backup. Isn't it possible to make EFS backup using fastboot? Also, do I need to make EFS backup while I'm on OOS? Can't I make EFS backup on a custom ROM?
    6) How do I return to stock OOS with locked bootloader?
    Thanks, in advance for all the help :)
  6. SirBacke
    Honeycomb Oct 18, 2017
    SirBacke , Oct 18, 2017 :
    It's a great guide! Except that I would root nowadays with Magisk / Magisk Manager instead of SuperSU. Then put Xposed Framework on top of Magisk (Special version available on XDA).
    (For rooting you won't need anymore a SuperSu or similar file because Magisk is rooting automatically when installing).
    Re 6): See search engine in this forum.
    SatriaPerdana likes this.
  7. RealUD7
    Gingerbread Oct 20, 2017
    RealUD7 , Oct 20, 2017 :
    I was hoping someone will help me out because I don't want to create a new thread for this given there are already quite a lot of stupid threads asking for Oreo. Even if someone notices my thread I will be redirected here but no one is helping me out. I'm hoping that @Funk Wizard or anyone else notices this and helps me out.
  8. G_Marius_Inspired_cDgV
    Cupcake Oct 31, 2017
    G_Marius_Inspired_cDgV , Oct 31, 2017 :
    Same here, any solutions? It get's stuck on the red dot and two white dots above frozen.
    EDIT: fixed it! Boot into recovery ---> Wipe ---> Proceed ---> Reboot to system after wiping
    EDIT 2: It seems it also wiped out the root. The problem was out-dated supersu package. Download the newest here: http://www.supersu.com/download
  9. Rubens Jr.
    Donut Dec 4, 2017
    Rubens Jr. , Dec 4, 2017 :
    I've followed all the steps carefully. I installed SuperSU, but after cleaning cache and reboot, the device stops loading on boot loop. Even the loop image stops and the led notification turns on.
  10. maner
    Cupcake Feb 17, 2018
  11. harshalhirve
    Cupcake Mar 16, 2018
    harshalhirve , Mar 16, 2018 :
    I have unlocked by bootloader but unable to flash TWRP. I am on Open Beta 32. While trying to flash twrp, it gives me 'max file size' error.... & nothing after that. All drivers installed properly & adb commands working fine.
    Please help !
  12. SatriaPr
    Ice Cream Sandwich Jun 24, 2019
    SatriaPr , Jun 24, 2019 :
    how to boot to twrp after flashing if my volume button is broken? (I come from AEX custom rom and it's amazing) anyway do i need modified(special) Twrp or just normal latest one for oos pie?
    Edit : solved, fastboot has an ui
  13. SatriaPr
    omg people don't use supersu anymore, use magisk instead it'll save you lots of troubles (I can help you, pm me if you need)
  14. Mohityadav7
    Froyo Jul 9, 2019
    Mohityadav7 , Jul 9, 2019 :
    Is this guide valid anymore? Help me master! I finally want to root my OnePlus 3 after 3 years \( ̄︶ ̄*\))
  15. SatriaPr
    Ice Cream Sandwich Jul 9, 2019
    SatriaPr , Jul 9, 2019 :
    Mohityadav7
    Is this guide valid anymore? Help me master! I finally want to root my OnePlus 3 after 3 years \( ̄︶ ̄*\))​
    Yea it's valid, just use magisk instead of supersu it's safer
    Mohityadav7 likes this.
  16. Mohityadav7
    Froyo Jul 9, 2019
    Ok, thanks! Currently I'm following this video. It uses Magisk. :)
  17. SatriaPr
    It's legit
  18. Jaggery
    Cupcake Sep 2, 2019
  19. M1568532544430
    Cupcake Sep 15, 2019
    M1568532544430 , Sep 15, 2019 :
    Hello guys..
    I am new, i come from iOS.
    Can i flash the "twrp version" of this guide on my 3T 9.0.5?
    Thanks
  20. muralidharc22
    Cupcake Mar 8, 2020
    muralidharc22 , Mar 8, 2020 :
    I am able to flash TWRP twrp-3.3.1-1-oneplus3.img successfully but not able to boot into the same but always stock recovery where as i can boot into TWRP using the command fastboot boot recovery.img via commond prompt.
    Please help to get rid off stock recovery comletely ( i am on 9.0.6)
