{GUIDE} ONEPLUS 3T Insane Battery Life and Perfomance Screen On Time (SOT) 7-8 Hours
  1. ashokmor007
    Honeycomb Feb 1, 2017
    ashokmor007 , Feb 1, 2017 :
    I'm about to tell you how to get buttery smooth, lag-free performance with insanely good battery life.
    EX KERNEL MANAGER:
    FEATURES
    Easy installation and setup with Aroma installer
    Optimized for performance and battery life
    Advanced color control
    Sound control
    Overclock or underclock CPU
    Notification light control
    Sweep2sleep
    Backlight dimmer option
    Wake Gestures (Sweep2Wake and DoubleTap2Wake)
    NTFS r/w support
    Option to disable fsync
    Adjust or disable vibration
    Dash charge
    Does not force encryption
    Compatible with systemless root
    DOWNLOADS:
    EX Kernel Manager
    Quick and easy updates and full control
    https://play.google.com/store/apps/...er-global-all-co-prtnr-py-PartBadge-Mar2515-1
    Kernel for OxygenOS (Android 7.0)
    https://www.androidfilehost.com/?fid=385035244224414818
    PROJECT ZHANA:
    https://mega.nz/#!nx10maSS!4SQb5zZvwGOmN_vaDtNigsc15COSyWmGPlRANhJmSsk
    Explanation for each variant:
    Project Zhana Balanced (Default): The Project Zhana that you know and love.
    Project Zhana Battery: Same as above, but with lower Input boost values and some tweak on target_loads, above_hispeed_delay and GPU
    Project X.A.N.A Battery (Default): This is default version of X.A.N.A
    Project X.A.N.A Balanced: The same as above but with higher Input boost and some tweaks for I/O and GPU, for a better performance.
    Project X.A.N.A Extrem Battery: If you are using this profile and you suffer lag don't even think on complaining since I won't listen. This is made for really light usage. No Input Boost, Battery saving I/O and GPU ...
    Source:
    https://forum.xda-developers.com/oneplus-3/how-to/advanced-interactive-governor-tweaks-t3476589
    Link removed by Moderator.
  2. puneetwangoo
    Cupcake Feb 1, 2017
    puneetwangoo , Feb 1, 2017 :
    I don't find it in my phone. if you are using your phone for games, surfing YouTube then may be it will be draining your phone but still I say it should work.
  3. Master_TC
    Jelly Bean Feb 1, 2017
    Master_TC , Feb 1, 2017 :
    Thank you. I don´t have any battery drain, but i will try it. I´m curious.
  4. main_shoby
    Donut Feb 2, 2017
    main_shoby , Feb 2, 2017 :
    comments on op forum... oh man it really tells me i don't belong here. this guide is to help people who need it and the dude put some time to write and collect sources. if you dont like it, just shut and move along. why bash his work?
    its a useful post.
    marnix11 likes this.
