{Guide} Oneplus 3T Ressurection Remix Rom (Installation/Quick Look)
  1. _DEDSEC_
    Jelly Bean Jul 29, 2017
    _DEDSEC_ , Jul 29, 2017 :
    It's your choice. If you want assign it's destination like c:/users/_DEDSEC_/desktop/recovery. It's much work. Or you could just drag and deploy in the shell. Make you sure you type every work till "recovery" and drag the file and put it in the shell, and hit enter.
    #81
    peaky blinders likes this.
  2. peaky blinders
    peaky blinders , Jul 29, 2017 :
    Right I'll have a go again. Something so simple being an *** haha. If I'm not back I've smashed up the laptop and my phone and spat my dummy out big time
    #82
    _DEDSEC_ likes this.
  3. _DEDSEC_
    No don't, I will explain the steps.
    Download the RROS from site.
    Download TWRP 3.0.4-1
    Download Gapps.
    Make sure you have All ADB and Fastboot drivers installed properly
    #83
  4. _DEDSEC_
    Now press shift + Rightclick and plug your phone to the PC.
    Type : Fastboot devices. If it doesn't show your S/N make sure you have installed the right drivers.
    Now type:
    Fastboot flash recovery (recovery file, drag and drop)
    Now boot to recovery and chose install.
    Go to the destination of RROS and install.
    Plug it to the pC again and flash Gapps via "ADB sideload (drag and drop the file)"
    your good to go.
    #84
  5. peaky blinders
    Got dm verity couldn't get rid of it then ended up bricking it. Used the recovery tool so back to the beginning. Will have to do it when i have time on my own.
    #85
  6. _DEDSEC_
    If you get DAM_verity just flash the stock kernal and type from powershell
    fastboot oem disable dm_verity_check
    fastboot oem enable dm_verity_check
    #86
  7. peaky blinders
    3 times i got DAM_verity
    #87
  8. peaky blinders
    I tried fastboot oem disable dm_verity_check and it wouldn't do anything at all
    #88
  9. _DEDSEC_
    Jelly Bean Jul 30, 2017
    _DEDSEC_ , Jul 30, 2017 :
    ok leave it for now. What happens to he ROM.
    #89
  10. peaky blinders
    peaky blinders , Jul 30, 2017 :
    Twrp was on my phone i tried to install RR but nothing it kept going back to twrp. Really don't understand what's going on.
    Now I'm back on stock in getting no notifications haha
    #90
  11. _DEDSEC_
    Could write the steps of everything you have done till now?
    #91
  12. peaky blinders
    Yeah that would be great
    #92
  13. _DEDSEC_
    Sorry, I meant could you tell what you have done till now. I already told you the steps.
    #93
  14. peaky blinders
    I don't know what it is or why but always get dm_verity
    Could do with a full guide with the unlock bootloader without dm_verity and twrp etc as it's getting annoying. Did it fine on my other 3t I sold
    #94
  15. _DEDSEC_
    #95
  16. peaky blinders
    #96
  17. _DEDSEC_
    Let's leave the DAM verity for now, it's a easy fix. Just tell me if you have installed the RROS or not. If not, how did you install it.
    #97
  18. peaky blinders
    Back on stock at the moment will try again later then let you know
    #98
  19. _DEDSEC_
    Ok. Just forget about the dm verity. We can fix that.
    #99
  20. peaky blinders
    I always get errors installing RR with twrp
